RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   What's the difference between an OS SF engine and an FP? (https://www.rcuniverse.com/forum/glow-engines-114/5707161-whats-difference-between-os-sf-engine-fp.html)
willits18 04-12-2007 08:07 PM
I have a bunch of engines that I have collected through the years and I am trying to decide which one to put in the D-7 I'm building. The SF .40 has a big case-same size as an OS .46FX, The Fp has a smaller case but with the same displacement. Are the Sf's more powerful than the FP's or just bigger?
Sandyt 04-12-2007 08:19 PM
RE: What's the difference between an OS SF engine and an FP?
The SF engines have ball bearing supported crankshafts, while the FP's have bushings. The FP is a good line, but the FP 40 will not have as much power as the SF 40. Also, the SF has a two-needle carb while the FP uses an air bleed carb. The two-needle is a much better carb.
Sandy T
meaden 04-12-2007 08:30 PM
I have a .45-46? SF that is pulling great after 10+ years of abuse and neglect. I know that dosen't speak to your power question. But it's a great engine, starts right up and goes.
w8ye 04-12-2007 08:34 PM
The SF was a predecessor to the FX and then the AX
The FP was a predecessor to the LA
Rcpilot 04-12-2007 09:58 PM
Whats the difference?
About 6yrs--ball bearings--and $20. [sm=lol.gif]
