RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Saito compression ? (https://www.rcuniverse.com/forum/glow-engines-114/5812584-saito-compression.html)
bigugly 05-04-2007 11:08 PM
Saito compression ?
I have a saito 72 in a Venus 40 and this is my first 4stroke. It feels like it has almost no compression ( its new never run) is this normal for a 4stroke. I have 3 OS 46 motors and they all have a ton of compression.
I checked every thing for tightness and I cant hear any air escaping.
Should I send it back or is this normal for a 4 ?
TIA
NM2K 05-05-2007 05:06 AM
RE: Saito compression ?
Yes, it can be normal for a new four-stroke of any brand not to have much compression. It will improve tremendously after the break-in ritual.
Ed Cregger
w8ye 05-05-2007 06:46 AM
On a four stroke, make sure the throttle is open a little or it will not have any compression.
bigugly 05-05-2007 09:14 AM
thanks for the replies. its was kinda bugging me ;)
scratchonly 05-05-2007 12:29 PM
Had the same thing with a new 91. Spun it over with an electric starter and it was OK???
daveopam 05-05-2007 04:12 PM
bugugly. This sound like your first four stroke. I like to pull the valve covers before the first run. I check the valve clearance and run some oil down the pushrod tubes. This will make sure the cam is lubed during the first start up. I use my after run oil which is a 50/50 mix of ATF and Marvel Mystery Oil.
David
bigugly 05-05-2007 10:49 PM
thanks ... that sounds like a good idea
