Best pipe engines
Or should I say will my engines, be helped on a pipe.....
I have a shrike 40 and plan to refit it with a piped engine, I have a O.S. LA .46 I heard LA's are not timmed for a pipe. Magnum XLS .46 BB ENYA SS40 BB What is the timming I'm looking for later ex. close? If anyone has any info on this .......Thanks bobbdd |
Best pipe engines
Either the Enya or Magnum will fly fine on a pipe....
Pass on the LA |
Best pipe engines
Hi!
Any modern twostroke engine will benefit from a pipe.....it's more a question of how much the improvement will be! You will see an improvement even on your OS LA engine! Regards! Jan K Sweden |
Best pipe engines
An engine with aggressive timing with benefit most from a tuned pipe. However, any engine will get some gains from a tuned pipe. Not as much as others but every engine will gain something. For an engine like the LA it's just not economical to pursue.
| All times are GMT -8. The time now is 06:44 PM. |
