RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   GP .40 Engine (https://www.rcuniverse.com/forum/glow-engines-114/596453-gp-40-engine.html)
Geistware 03-03-2003 12:19 AM
GP .40 Engine
Russell has a magnum GP .40 engine, he can't get the piston rod to disconnect from the crankshaft, Is there some trick to get the rod off the crankshaft?
pikebishop 03-03-2003 02:18 PM
GP .40 Engine
pull the liner out first then you will have enough play to remove the con rod from the crankpin.
RCaeroguy 03-03-2003 05:03 PM
GP .40 Engine
Yup, that's what I did. I just had mine apart for some love.
