RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Checking crashed engine (https://www.rcuniverse.com/forum/glow-engines-114/61154-checking-crashed-engine.html)
lennyk 02-23-2002 11:31 PM
Hello,
I have a crashed Saito 91 engine, the crankcase at the back has
a crack.
I am not sure if the crank is bent, there is a little friction when it
is turned and it can do a full turn. The bearing are probably
crushed which could be causing this.
What is the best way to check if the crank is bent ?
I see in the previous post, guys are talking about forcing it back straight. What are the implications ?
Worse case I have to buy crank, bearings, crankcase, carb.
Best cast I would not have to buy the crank.
The bearings are NTN type, would these be the same which are
sold by NTN distributors for auto/machine etc ?
L
John B 02-23-2002 11:59 PM
Get your bearings from www.bocabearings.com I check the cranks with a dial indacator myself but if it is bent I would replace it. Boca sells a set of bearings for that engine fo 20 bucks, dunno what a crank cost, but if the bearings are crushed its pretty hard to get a reliable reading on the crank. Id check over the rest of the engine real close .....anyore damage and it might not be worth repairing. If so ,buy a new one and in your old one you have a extra jug for it .
