RE: Thundertiger .75
ORIGINAL: Jazzy It may be that the prop is too small. I'm running an APC 11X7 on a TT 54 four stroke... perfect combo. I realize you're still breaking it in but I'm thinking a 12X6 or 8 might be a better choice. |
ORIGINAL: XJet ORIGINAL: Jazzy It may be that the prop is too small. I'm running an APC 11X7 on a TT 54 four stroke... perfect combo. I realize you're still breaking it in but I'm thinking a 12X6 or 8 might be a better choice. |
instead of putting it in the Expo 3D ive decided to put it in a tiger moth I have, ive got a 12x9 and a 12x4 prop, so ill finnish the moth off and see what it runs best on, hopfully i can get the tank below the spray bar, typical inverted engine mounting.
isamike, while a 12x4 might be fine on a .40 size four stroke, I don't think I'd try one on a .75. It couldn't do a .75 any good. A 12x9 sounds about right.
good stuff, thanks mate
I had several flights over the weekend with the .75. The prop was an APC 11 X 7 which is not enough prop. It turned around 10,200 rpms. I hope to get a 13 X 6 or 7 APC and try again later in the week. The engine seems to be running quite well.
Cajunchrley |
ORIGINAL: Cajuncharley I had several flights over the weekend with the .75. The prop was an APC 11 X 7 which is not enough prop. It turned around 10,200 rpms. I hope to get a 13 X 6 or 7 APC and try again later in the week. The engine seems to be running quite well. Cajunchrley Can you verify the weight with muffler? Thanks, Dave |
I ran the .75 with an APC 13 X 6 prop, and got about 9850 to 9900 rpms, and was really pleased with the performance. I also have an APC 13 X 7 which I will try (weather permitting) this weekend. As I recall, the engine weighs about 17 ounces.
Cajuncharley |
Today I ran the engine with an APC 13 X 7, and it turned around 8850 to 8900 rpms. I think I will stick with the 13 X 6 (which turned at around 9850 to 9900 rpms).
Cajuncharley |
Cajuncharley |
| All times are GMT -8. The time now is 04:27 AM. |
