RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   OS Pump Substitute (https://www.rcuniverse.com/forum/glow-engines-114/6295712-os-pump-substitute.html)
duke 08-27-2007 08:43 PM
OS Pump Substitute
Have a OS FS 120 III with leaking fuel system. Is there an aftermarket "durable" fuel pumping system for my engine? Thanks in advance.
w8ye 08-27-2007 09:19 PM
RE: OS Pump Substitute
http://www.perrypumps.com/
airbusdrvr 08-28-2007 06:27 AM
Would a Cline Fuel Regulator, http://www.billsroom.com/pcfs/produc...uelsysdesc.htm, perhaps work as well? It would probably be simpler to install and there is no pump to adjust. Just readjust the carb to work with the regulator.
w8ye 08-28-2007 07:10 AM
The OS pumped engine already has a regulator built into the carburetor
airbusdrvr 08-28-2007 07:20 AM
Reference the Cline suggestion: As Gilda Radner used to say, "Never Mind."
