RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   OS engine ID (https://www.rcuniverse.com/forum/glow-engines-114/6595171-os-engine-id.html)
elmshoot 11-07-2007 10:32 PM
OS engine ID
I got a rather large OS engine in an estate sale. It runs fine on the test stand but I don't know what it is. The markings on the case say "BX1" Any ideas? I think it might be a 1.08 but it seems to large for that engine.
Sparky
w8ye 11-07-2007 10:40 PM
RE: OS engine ID
http://www.osengines.com/history/osm...bgx-1-ring.jpg
da Rock 11-07-2007 10:53 PM
RE: OS engine ID
ORIGINAL: elmshoot
Sparky
Look on the engine under the exhaust outlet. They usually placed the displacement of the engine right there.
proptop 11-07-2007 11:12 PM
RE: OS engine ID
Isn't the BGX-1 a 30cc? IIRC it is...that would make it a 1.80 c.i.
Edit: I see that it's actually 35cc (thanks FBD )
w8ye 11-07-2007 11:23 PM
RE: OS engine ID
Here's the manual
http://manuals.hobbico.com/osm/bgx-1-ring-manual.pdf
rainedave 11-07-2007 11:41 PM
RE: OS engine ID
1 Attachment(s)
I've never seen this in any of my OS manuals before:
Flyboy Dave 11-08-2007 01:20 AM
RE: OS engine ID
1 Attachment(s)
ORIGINAL: elmshoot
Sparky
You are correct....the BX1 is the same as the old 1.08 FSR. At one time the
OS 1.08 FSR was just about the most powerful engine made. ;)
The BGX-1 is actually a 35cc engine.....much larger than the 1.08.
I have a couple of the big ones....and one of the OS Pitts style mufflers. ;)
FBD.
Dr1Driver 11-08-2007 07:36 AM
RE: OS engine ID
Has anyone ever converted one of these big OS engines to gasoline?
Dr.1
Iflyglow 11-08-2007 10:42 PM
RE: OS engine ID
I seen a BGX converted to gasoline with C&H ignition and a walbro carb, and the performance was sad. You have to run a very rich oil to fuel ratio (if I remember correctly it was 16-1 or 20-1) because of the bushed connecting rod. All decent gas engines use needle bearings on the connecting rod. The engine was mounted in a Midwest AT6 and the performance was lousy. It also ran alot hotter than the glow version (lack of proper cooling fins). I would not mess around tring to convert it.:eek::eek: The owner eventionaly converted it back to glow.:D
