GMS 1.20 Engine
Anybody out there have any info on GMS engines, regarding reliability, power, etc? I am considering buying a GMS 1.20 for my next P-51 project and their price is right but I don't know much about these engines.
Thanx, Mark |
RE: GMS 1.20 Engine
The GMS 120 is not as highly tuned as some of the smaller GMS engines. Its a rather mild runner
Undoubtedly this has prompted your inquiry? GMS 1.20 Aero Ringed, Double Ball Bearing $119.99 each Save Buy 2 for just $199.98 $189.98 (94.99 ea) with $10.00 off That's Only $94.99 Each This 141 engine is made by the same company and has a little more power? http://www3.towerhobbies.com/cgi-bin...&I=LXFV80&P=ML |
RE: GMS 1.20 Engine
The GMS 1.20 2-stroke is the finest 1.20-sized glow engine on the market... at the $94.99 price point, anyway. :D
I've run some of GMS's smaller engines and I thought they were quite powerful and a great value. The 1.20 in particular has a bit of a reputation for being difficult to tune. If you're not very, very comfortable with breaking in and tuning 2-stroke engines, you might want to consider another choice. If you have some tuning experience, however, the GMS 1.20 is a bargain. |
RE: GMS 1.20 Engine
Can you be more specific about why they are difficult to tune? Is it setting the idle or hi speed adjustment? Or is it that the engine has unreliable performance? Please advise.
Thanx, Mark |
RE: GMS 1.20 Engine
If you buy a GMS 1.20, there's a better than even chance that it will run very rich in the mid range (1/4 to 3/4 throttle), especially in-flight, even if your low speed and high speed needles are adjusted correctly. It appears that at least some of these engines suffer a carb calibration problem in the mid range throttle zone.
We have one flying at our field. It has a Pitts style muffler fitted (this may or may not be contributing to the problem) and despite tuning it as lean as possible, we cannot get rid of the mid range richness. Running an OS type F plug helped make the engine a little more resilient against the stumbles and occasional flame-outs caused by this mid range richness. The engine at least now provides reasonably reliable service, but its mid range richness would drive me insane if I owned it. |
RE: GMS 1.20 Engine
Would crimping the fuel line or using a smaller ID line, thus lowering total fuel flow; fix the midrange problems in engines with bad fuel metering carbs??
RE: GMS 1.20 Engine
i have a well used gms 76 that is a great performer.
unlimited in most 60 size aerobats. BUT! like big ed said. you better be ready for a long breakin period. and the low end needle is very touchy. once the engine seats in provided you break it in corectlly it ll be fine. mine will idle all day and never misses. low end is around 5/8 turn out |
RE: GMS 1.20 Engine
ORIGINAL: Harry Lagman If you buy a GMS 1.20, there's a better than even chance that it will run very rich in the mid range (1/4 to 3/4 throttle), especially in-flight, even if your low speed and high speed needles are adjusted correctly. It appears that at least some of these engines suffer a carb calibration problem in the mid range throttle zone. This cures the mid range transition problems once the engine is broken in. |
| All times are GMT -8. The time now is 05:36 PM. |
