RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   what is a cline regulator? (https://www.rcuniverse.com/forum/glow-engines-114/668296-what-cline-regulator.html)
Kruges 04-03-2003 04:58 PM
i was told by someone that i need a cline regulator if i want to move my tank back to the cg on a h9 cap232. i am running a satio180. i have put this name onto searches on some of the manufactureres sites and come up with nothing . can someone tell me
who makes them and where ican get one. thanx!
please remove my thread as i have found out what i need to know on another thread.thanku
outssider 04-03-2003 05:57 PM
http://www.billsroom.com/pcfs/fuelsysdesc.htm
ACROHUNTER 04-03-2003 09:22 PM
Re: what is a cline regulator?
Hi Kruges,
The cline regulator is designed to stop the fuel when the engine is nor running. If you have the carburetor installed lower than the tank, the fuel will continue flow when you stop the engine.
If you have the carburetor facing down maybe youŽll not need it because the fuel will drop to the floor, no inside the cylinder which is the risk of that.
Regard
