RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   K&B 1.00 square back muffler (https://www.rcuniverse.com/forum/glow-engines-114/6993232-k-b-1-00-square-back-muffler.html)
Broken Wings 01-29-2008 09:32 PM
1 Attachment(s)
Does anyone have any experience with these?
Hobbsy 01-29-2008 10:05 PM
RE: K&B 1.00 square back muffler
Yes, I have had one for several years. It was originally on a BTE FlyinKing. I took it off of the FK after while because it stuck out the front so far. It has spent 95% of its life converted to Diesel.
huck1199 01-29-2008 10:09 PM
I bought one a while back and I am going to put it on a 1/4 scale Laser 200. I like K&B, USA made, good quality. I haven't run this yet but if it runs like the other K&B's I have I'm sure it will be OK.
I like the mounting style - the muffler box mounts to the firewall with exhaust out the bottom. No expensive pipes to buy. How do intend to use yours?
Huck
codycarlisle25 01-30-2008 11:57 PM
I am curious about this engine. I always thought the muffler/ mount begged for a scale application. I'm sure you could gain more power with a different exhaust and I have wondered how it would respond to a pipe. I do think Mecoa has kind of priced it in the "too bad" category. I still wonder about the engine, but will probably never get to see one.
cody
w8ye 01-31-2008 12:28 AM
This version of the 100 is rather mild. It will not respond as well to a pipe as some other engines that are tuned a little hotter
Broken Wings 05-22-2008 08:30 PM
1 Attachment(s)
I found one NIB on *bay. I also found the RCM engine review. Apparently they're timed a little racier than I thought. It looks like the muffler is very restricting. I'm collecting Balsa for a Big John biplane that I have plans for.
Here's the report if anyones interested.
http://www.rcmmagazine.com/index.htm...mBXfXAgTA5B621
Look under reviews.
w8ye 05-22-2008 08:40 PM
Adobe says the PDF file is damaged
Broken Wings 05-22-2008 08:45 PM
I just opened it. Should I try loading it again?
I found it on the RCM plans website under reviews.
rcdude7 05-22-2008 08:45 PM
Just curious, where do you find the RCM engine reviews like this on the internet? My favorite part of RCM magazine was the engine column and reviews by C.F. Lee.
Broken Wings 05-22-2008 08:47 PM
Sorry, the RCM plans web site has a reviews section.
maybe this will work.
http://www.rcmmagazine.com/issues/re...mBXfXAgTA4L2G7
w8ye 05-22-2008 08:48 PM
If you can load it then maybe something is wrong with my computer but I was just looking at a couple PDF manuals on the Tower site.
turbo.gst 05-22-2008 09:56 PM
Thanks for the link to the RCM review Broken Wings. It would appear tha CF Lee seems to think it would respond very well to a pipe. I hope to get to find out someday.
turbo
Broken Wings 05-22-2008 10:19 PM
ORIGINAL: turbo.gst
turbo
Do you run one of these?
I noticed that the "outboard" and "fan" engines use different part numbers for the cylinders. It might be interesting.
For some reason I've always been attracted to somewhat "odd" model engines. It's a hobby right...;)
turbo.gst 05-22-2008 10:24 PM
I have one, but havent run it yet. I will try several carb/ muffler setups. I just need to find the time.......
turbo
Hobbsy 05-23-2008 07:01 AM
BW, if my Sweety doesn't keep me too busy and my Harley doesn't sit up and beg I may run mine both as a glow and as a Diesel just for some engine runnin fun. Mine has been boxed up and Corrosion Xed for a couple of years. I have some 5% fuel with 16% lube that I added 3 oz of castor to.
Broken Wings 05-23-2008 11:10 AM
I'd be interested in the data.
Hobbsy 05-23-2008 12:56 PM
1 Attachment(s)
John, my neighbor has a crew of guys repairing his house roof so I was hesitant to run the engine more than about 5 minutes so I didn't do the Diesel run. The glow run was done with the following, my run is 200 rpm sronger than Mr. Lee's possibly due to mine having many hours on it. This a very smooth engine and will be easy on the airframe.
Prop APC 14x6, rpm===10,400, 10,500 was attainable but it wandered up and down a little 10,400 was rock steady.
Plug Fox idlebar
Fuel WildCat 5% with 16% 80/20 blend and 3 oz of castor added.
Sport_Pilot 05-23-2008 02:57 PM
A 1.0 seems a bit small for a 1/4 scale model. Especially an aerobatic one.
Broken Wings 05-23-2008 03:11 PM
ORIGINAL: Hobbsy
Plug Fox idlebar
I like it!....They're just odd enough that they might be worth something one day.
I think I got a good deal, $127.50 NIB less shipping.
submikester 05-23-2008 11:27 PM
It's a good looking motor for sure and those numbers are very nice - I bet it would pull a 14x8 well enough - maybe a 13x9 or so...
There is a fellow over on the warbirds forum who is planning to put one in his new TF 1/7 scale Mustang ARF.
http://www.rcuniverse.com/forum/fb.asp?m=7530472
Hobbsy 05-28-2008 04:36 PM
1 Attachment(s)
Here is mine converted to Diesel running Davis ABC fuel turning a Graupner 15x8 at 8,175.
Broken Wings 05-28-2008 05:48 PM
1 Attachment(s)
Hobbsy, UPS just brought mine to the door, It's alot smaller than I had imagined and the carburetor is a little different than yours. It looks like they did away with the ecentric adjusting screw and added a small wire "clicker" that rides in the notches of the low speed mixture adjustment.
The crank is beefy at 3/8-24...
I like it. :D
Now I'm wondering if I can rotate the cylinder on the .65 Sportster and machine a muffler/mount for it as well.
I found it on *bay, it looks a little better now....
Hobbsy 05-28-2008 07:35 PM
John, I think my .61 Twist has that same or very similar carb., I have a .65 that I don't consider too valuable if you need some parts for that one. The 1.00 looks good, let us know how it runs.
huck1199 05-28-2008 08:31 PM
Sport Pilot
The Lanier Laser 200 1/4 scale is not a big plane, 72"ws and 8lbs. Recommended engine is .60 to 1.08 2 cycle. I thought this would be enough power. I am not an accomplished aerobatic pilot, my skills are limited at this time.
Have you seen Laser 200's? what sort of power were they using?
Thanks Huck
Sport_Pilot 05-29-2008 07:30 AM
Then I guess a Lazer 200 is a bit smaller than the usual Extra or CAP.
