RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   OS91 pumped (https://www.rcuniverse.com/forum/glow-engines-114/7054843-os91-pumped.html)
hubbajer 02-10-2008 06:31 PM
OS91 pumped
Does anyone happen to know If you can simply remove the pump and run the engine as a FS91 II? Are there any changes needed and is there any downside to doing this? I have a chance to pick up a late model but I realy don't care for a pumped engine. Thanks for your input.
w8ye 02-10-2008 07:35 PM
RE: OS91 pumped
[ul] These are the parts that are different[*] Back plate [*] Carb[*] Intake manifold
[/ul]
hubbajer 02-11-2008 07:43 PM
RE: OS91 pumped
Thanks for the reply, that answers my question
gexx 04-23-2009 01:39 AM
RE: OS91 pumped
Must I really change the backplate and the intake manifold?
If you use the backplate of the FS91 with Pump the new carburetor would only be a little higher because the pump version of this engine needs a little more space in the backplate area for mounting the pump unit.
Without changing the backplate you can use the original intake pipe which is a little shorter then the intake manifold of the non-pump Version.
But the manual shows also different main needles.
Best regards
Robert
