RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   New engine Prob (https://www.rcuniverse.com/forum/glow-engines-114/7211235-new-engine-prob.html)
runt_71459 03-11-2008 07:50 PM
New engine Prob
Just got a OS .46 to replace a .40 magnum(RIP) but I can not even start it! The engine is hard to rotate, my arms got tired priming it. Also with it that hard my starter will not rotate it. What is the problem? Or What should I do?
sam_dwlng07 03-11-2008 08:01 PM
RE: New engine Prob
try cracking the glow plug while starting it , it will be hard until you get it brokr in.
runt_71459 03-11-2008 08:15 PM
RE: New engine Prob
I have checked the glow plug a few times before I quit because my arms got tired. Just got a gym membership today!
longdan 03-11-2008 09:12 PM
RE: New engine Prob
Try warming it up with a heat gun, or even a hair dryer before starting it.
DarZeelon 03-12-2008 02:13 AM
RE: New engine Prob
Runt,
The OS.46AX/LA/FX should not be that hard to turn...
Is it only hard going over TDC/compression, or is it hard to rotate all around?
As to break-in, please read this:
ORIGINAL: DarZeelon
If you want to follow this break-in thread, it is [link=http://www.rcuniverse.com/forum/Tapered%2DBore_Engine_Break%2Din_%2D_Upgraded/m_1850473/tm.htm]right here[/link]!
Even "Hobby Services", the OS importer for the USA, [link=http://osengines.com/faq/product-faq.html#q2]agrees[/link] the procedure OS describe in the manual is flawed... OS don't seem to 'second guess' their US rep, but for some reason seem reluctant to rewrite their manual...
But this is the way OS usually work... Never admit there is a problem and it will eventually go away...
Please open the underlined links to understand better.
FlyingPilgrim 03-12-2008 03:46 AM
RE: New engine Prob
If it's just that the compression is high, or the pinch of the tapered cylinder is too tight, do as Sam suggested above, and loosen the glow plug a quarter turn or so. Then use your electric starter to get it fired up, and cinch the plug tight as it is running (careful of your prop!). I've had .12 & .15 size car engines that required this before my starter box would turn the engines over to start. Once it is broken in, it should not require this.
Also, like Dan said, if the pinch is really tight, pre-heat it with your heat gun to expand the cylinder right before your starting attempt. That loosens up the tight fit enough for starting. Again, not necessary after break-in.
runt_71459 03-12-2008 10:16 PM
RE: New engine Prob
I will try both this weekend! Thanks for the comments! But I will get it running or you will see it on the classified ads!
rcdude7 03-12-2008 11:47 PM
RE: New engine Prob
ORIGINAL: runt_71459
Just a hint here, Don't sell it, the tightly fitted engines are usually the most powerful after break-in.
