RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Saito question? (https://www.rcuniverse.com/forum/glow-engines-114/7472161-saito-question.html)
rclement 05-08-2008 03:02 PM
Saito question?
How do you get pressure in the fuel tank if you are using a Saito flex exhaust? A couple of guys at the field have been trying to convert there exhausts to use these flex tubes but say they aren't getting enough flow from the fuel tank without a nipple and tube to pressurize the tank.
Ernie Misner 05-08-2008 03:21 PM
RE: Saito question?
You install your own pressure fitting up near the header somewhere, where there is enough meat to drill and install it. It works great if you use a 90 degree alum. adaptor that you can drill into for sure.
Ernie
w8ye 05-08-2008 04:43 PM
RE: Saito question?
Some of the flex pipe come from Saito with a pressure nipple
rclement 05-09-2008 10:59 AM
RE: Saito question?
Thanks guys. Yeah, one that I've seen has the 90 degree adapter so he was planning to drill it and put a nipple on it.
