CDI ignition system on a glow engine
Hi!
Anyone tried to convert a glow engine to a "gasser"? Just engines sells a CDI system with a glow plug thread spark plug. If this works well, it can cut fuel costs significant! Also reduce on board fuel weight. But I'm a little concerned about the carb. Maybe it will need some modifications? And what about the bushings in the con.rod? here is a link to the CDI-system: http://www.justengines.unseen.org/ac...s_Systems.html |
RE: CDI ignition system on a glow engine
The original carb needle adjustment will be very sensitive
The original rod will work OK if you run oil 16:1 or richer Engine will run a little hotter and will not have as much power as before There is another brand called C-H Ignitions http://www.ch-ignitions.com/ |
This has been largely discussed over the Engine Conversions forum
http://www.rcuniverse.com/forum/forumid_92/tt.htm |
Yep, I have three threads in engine conversions as Francisco says above.
http://www.rcuniverse.com/forum/m_6655734/tm.htm http://www.rcuniverse.com/forum/m_7282593/tm.htm http://www.rcuniverse.com/forum/m_7363193/tm.htm Enjoy, Jezmo |
| All times are GMT -8. The time now is 05:43 PM. |
