RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   YS Engine Check Valve (https://www.rcuniverse.com/forum/glow-engines-114/7840980-ys-engine-check-valve.html)
jonathancassar 08-13-2008 09:31 AM
Can someone tell me if the check valve to be installed on the pressure line going to the tank is supplied with all new YS Engines? I have just purchased a YS FZ110 S and I don't know if I should buy a check valve or if it is actually supplied with the engine.
chepenik 08-13-2008 09:57 AM
RE: YS Engine Check Valve
Jonathan,
Check valve supplied with my new FZ110S was wrapped in a little plastic bag and buried in a hole in the grey packing material inside the box which contained the engine; little bag also contained the spring which detents against the needle valve. You may wish to carefully inspect nooks and crannies inside box and hopefully find this little bag.
Happy Flying!
Ken
jonathancassar 08-13-2008 04:59 PM
Hi Ken. Thanks for your reply. That puts my mind at rest. My YS was sent out yesterday. Should be here in a couple of days. Its my first YS engine so I hope that I'll have a good experience with it. It'll be going into my Funtana X100.
chepenik 08-13-2008 11:24 PM
Hello Jonathan,
Best wishes for success with your new engine.
Ken
