4 blade prop
can you use a 4 blade prop on a saito 1.20. plane is around 10lbs.? and what size prop would you use? where can one be purchased?
4 blade prop
Here is a conversion chart to convert from a 2-blade prop to a 4-blade prop: http://www.zingerpropeller.com/_2_blade_.htm
You can order a 4-blade prop from Zinger. |
4 blade prop
Hi!
ofcourse you could ..but you would not get any performance using one. Regards! Jan K Sweden |
4 blade prop
that's right,that 4 or 5 mph that you will lose,using a 4-blade over a 2-blade is sure gonna hurt you! i hear this argument all the time. give me a break! if i start listening to all the crap about efficency,or lack there of in multi-blade props,i might have to go home and pull the 4-blade off my .o.s. .46 powered GP spitfire.lordy,the thing only flies at 100+now,that extra 4-5 mph sure would come in handy! just my 2 cents.
prop
This 1.20 is going on my TF P-51 7th scale. I thought it would look better having a 4 blade prop. Another question is how scale would the right prop look?
4 blade prop
The right size prop will not look scale. You are looking at a 14x6 or a 14x7 four-blade prop on a 1/7th scale Mustang. The prop will look too small. This prop will look OK on a .40 size Mustang but not on a 60 size Mustang. If you want to swing a scale 4-blade prop, use either the RCV 90 or the RCV 120 four stroke.
4 blade APC available
I bought a 4 blade APC prop a while back - have never mounted it though. Bought it as a bit of a novelty as it's one cool looking prop and I will eventually use it. It's I believe an 11 X 8 intended for .90 4 strokes (or strong 60 2 strokes) and has very thin narrow chord blades. It looks pretty darned efficient to me!
Four Blade
JRCoone,
That is the exact purpose of a display prop. You can have a scale size, four-blade display prop. Just don't go flying with it. Use a correctly sized, efficient flight prop. Sincerely, |
| All times are GMT -8. The time now is 08:58 AM. |
