enya 30 ss
hello I have an enya ss .30 that needs to be rebuilt totally are there engine kits available for this engine if so could you send me information on it .
Thank You |
enya 30 ss
There really is no rebuild kit available for this engine. What exactly did you need?
enya 30 ss
First of all thank you for the fast reply well I need a piston connecting rod,wrist pin and cylinder . The wrist pin on mine was bent when I got the engine any info you can give me would be appreciated.
enya 30 ss
The piston and sleeve set sells for $48.20, the connecting rod is $14.50, and the piston pin $4.30. Everything is in stock except for the piston pin. If you would like to order these parts you can call us at 732-225-6144, and either Carol or I can help you with it. Or you can send it in for repair and we can fix it for you.
