RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Modified engine position. (https://www.rcuniverse.com/forum/glow-engines-114/8266715-modified-engine-position.html)
Lille-bror 12-21-2008 04:04 AM
Merry christmas :D
A friend of mine has bought a second hand bi plane. Original the glow engine was placed upside, but after the first flight the plane crashed, and afterwards he inverted the engine. Now the center line of the propeller is located 1” above the center of the fuselage.
Will that affect the flight characteristics? - Because the plane is close to impossible to handle in the air.
krayzc-RCU 12-21-2008 12:00 PM
RE: Modified engine position.
wow i would also be checking the indences on all surfaces.
TFF 12-21-2008 01:32 PM
It will change the way the plane flies, but it could change it for the better. Things like knife edges could change, with the plane pulling one way or the other but In normal flight it probably wont matter that much.
Lille-bror 12-24-2008 04:15 AM
Thanks for your replies gentlemen :-)
Merry Christmas
w8ye 12-24-2008 04:37 AM
The plane is most likely tail heavy
TomCrump 12-24-2008 04:52 AM
ORIGINAL: w8ye
I don't understand why this would be. Can you elaborate ?
w8ye 12-24-2008 05:03 AM
A plane must be balanced front to rear about a point 25% to 35% of the overall wing width from the front of the wig in order to fly correctly.
If the tail is heavy they are almost impossible to control. If they are very nose heavy they are hard to keep the nose up on landing
You have a biplane but you must treat both wings as one and find the point 25% back and you must support it by the top wing
TomCrump 12-24-2008 05:07 AM
ORIGINAL: w8ye
A plane must be balanced front to rear about a 25% to 35% of the overall wig width in order to fly correctly.
I agree, but he hasn't changed anything but the position of the motor, ie, upright to inverted. How would this change the balance ?
w8ye 12-24-2008 05:13 AM
It crashed the first time he flew it. The plane may have been tail heavy when he bought it?
Maybe he doesn't know how to fly?
On the internet it is hard to tell all the little details sometimes?
jaka 12-24-2008 08:04 AM
Hi!
The engine position will not change the planes flight characteristics (not much anyway).
Have you checked if the wing has wash-out (or worse... wash-in)? C of G, both lateral and axial? Wing loading ?
Lille-bror 12-26-2008 07:11 PM
Merry Christmas gentlemen.
I'll post your replies to him. Hope he will get it fixed... He has only been flying electric, and perhaps not the most patient guy I have met...
Thanks ;)
This thread is closed.
