Prop Help!!
Maybe this isn't the place for this but again maybe it is. Can someone out there help me? Recently I came acrossed a large (14") aluminum peop at a yard sale and bought it. The thing that is really different about it is that it is REVERSE PICH. The only marking I see on it is a #1 stamped into the hub on the front side. Does anybody out there have any idea what I have??
Thanks :confused: |
cool
I cant help you find out what it is :( , but it sounds cool. So it is a big 14 inch aluminum pusher prop? Maybe if you put it on a weedwaker engine you could make urself a lil airboat for you to ride around on :D
Prop Help!!
Whatever it is you've got, AMA rules don't allow use of metal props.
Prop Help!!
polish it up put it on a show plane and that's it
Prop Help!!
It might be something from a GHQ, or a similar engine from the 40's? Or maybe something somebody hand-made...Just a guess...A GHQ was a kit engine way back when, used for free flight planes, etc. but most of them didn't run, because of poor quality materials and workmanship.
| All times are GMT -8. The time now is 12:08 PM. |
