Prop Question
What is the point of a prop with a varying pitch along the blade, such as the Zinger 12x6-10? Is it an attempt at the best of both worlds - more static thrust and a higher top speed?
Thanks - NJD |
Variable pitch
NDJ,
An attempt, yes. But from what I read about it elsewhere it RCU, it is not a very successful one. Use a normal prop that moves your plane as you want. Sincerely, |
| All times are GMT -8. The time now is 02:39 PM. |
