Tuning specs
What are the specs for tuning a 46 magnum gas engine?
RE: Tuning specs
Welcome to RCUniverse
There are different Magnum 46's depending on their age but the tuning is pretty much the same You need to tell us what you have on hand for running the engine so we can discuss all the aspects and sort of find out how much you already know about these engines Here is the manual for the current XLS 46 series [link=http://media.hobbypeople.net/manual/210756.pdf]Magnum XLS 46 manual[/link] |
RE: Tuning specs
High Speed Needle Valve
The high speed needle valve is used to meter the air/fuel mixture at full throttle. Turn the needle clockwise to lean the mixture or turn the needle counterclockwise to richen the mixture. When you start the engine for the very first time the needle valve should be turned in completely, then backed out 2-1/2 turns. When you start the engine after that, leave the needle valve in the same position it was in when you shut down the engine. Low Speed Needle Valve The low speed needle valve regulates the air/fuel mixture at idle and during transition from idle to full throttle. Turn the idle mixture screw clockwise to lean the mixture. Turn it counterclockwise to richen the mixture. The idle mixture screw is preset from the factory, but minor adjustments may need to be made. To reset the mixture screw to the factory setting open the carburetor barrel completely. While holding the barrel open, turn the mixture screw in until it stops. From this point, turn the mixture screw out 2-1/2 turns. This is the factory setting. |
| All times are GMT -8. The time now is 06:35 PM. |
