RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Prop/thrust washer (https://www.rcuniverse.com/forum/glow-engines-114/8498855-prop-thrust-washer.html)
cruzomatic 02-20-2009 04:12 PM
Prop/thrust washer
I somehow lost two prop washers to two different engines. (Mag.91RFS and Saito 1.80FS) Can they be purchased at a hardware store? Sizes???
Ram Jet 02-20-2009 05:20 PM
RE: Prop/thrust washer
I would try a stainless fender washer. Just take your engine with you. It doesn't have to be metric but find one that fits closely to your prop shaft. If you have a buffing wheel you can make it look like chrome.
Bill
jeffie8696 02-20-2009 07:03 PM
I would look to Fastenal and see if they have anything in a hardened washer.
Ram Jet 02-20-2009 07:17 PM
ORIGINAL: jeffie8696
Better yet. It wouldn't be foolish to use a hardened washer. Especially if your engine is large. You might also check with a local hobby shop if you are lucky enough to have one.
Bill
w8ye 02-20-2009 09:06 PM
Saito 180 prop washer
http://www.horizonhobby.com/Products...ID=SAI170R3135
Magnum 91 Four Stroke
http://www.hobbypeople.net/gallery/280208.asp
Ken6PPC 02-20-2009 10:17 PM
By all means, buy an original replacement from the sources w8ye referenced above. You do NOT want anything that is a sloppy fit on the threaded end of the crankshaft! That would result in a lot of vibration, or worse.
w8ye 02-20-2009 10:19 PM
ORIGINAL: Ken6PPC
THIS IS VERY IMPORTANT!
DarZeelon 02-21-2009 04:21 AM
ORIGINAL: Ken6PPC
Ken, I think not.
Any washer that is the correct size will do the job
If we take an extreme case of an improvised steel washer, with a thickness of 2 mm and an O/d of 30 mm; even if this washer does have a very sloppy fit on the end of the shaft (with a hole 1 mm larger in diameter than the shaft thread), the imbalance calculates to ~23.5 cubic mm of steel (specific gravity 7.8), which are 0.18 grams 1.5 cm from the center, or 0.12 grams/cm.
This is equivalent to an imbalance of less than 0.006 gram at the blade-tip of a 16" prop...
I don't think you can really feel such a level of vibration, at ~9,000 RPM, even if it was an electric motor spinning this prop...
With any single-cylinder glow engine, which inherently suffers from a partial primary balance, this will really be imperceptible.
...So much for using expensive magnetic balancers, for props intended for such engines...
asmund 02-21-2009 04:43 AM
I use to balance all my props very thoroughly, but since I got into high performance electrics I`m not able to balance the tiny 4.1" to 5" props. They are so light-weight that they don`t move at all on my magnetic balancer, making balancing impossible. Maybe they all are perfectly balanced from the mold? I have began to just slap them on and fly, I have not experienced any problems or vibration to speak off so far. I turn these props from 28 000 rpm to 42 000 rpm static. Too little mass I think, to make a difference.
Edit: This is me flying my Zagi Typhoon 430 in the early days of development, it is faster now:) One shold think that these props would need to be balanced, but maybe they aren`t so bad to begin with.
http://www.youtube.com/watch?v=N_1uW_Ix8cs
Yeah, I know this isn`t glow, but I feel it fits this balacing thread somehow;)
Bottom line is that I agree that a small imbalance of a small washer on the output shaft turning about 9-12K propably will not be noticed at all
Ram Jet 02-21-2009 05:18 AM
ORIGINAL: asmund
FASTER NOW? Gawd. Jack Northrup would be proud.
Bill
Luna_Rendezvous 02-21-2009 07:14 AM
ORIGINAL: asmund
Try and get the tips of the metal shaft as close as you can to the magnets, but not touching. Then apply a little pressure with your hand to the bottom braces, this brings the shaft closer still, and is a way to fine tuning the shaft to magnet distance. I can actually balance the shaft and the hubs separately with this method.
Nice flying on the Typhoon, love sound of that screaming lecky.
asmund 02-21-2009 07:16 AM
Oh, thanks for that tip. I will definately try it out;)
Ken6PPC 02-21-2009 04:55 PM
Dar, you are probably correct about the washer. It isn't that big or heavy.
I was actually thinking about a situation where a friend of mine lost the crankshaft adapter for his spinner. The hole in the spinner was a little too large for the crankshaft, and it vibrated so badly he thought his engine was JUNK! When I found that the spinner was missing it's adapter, I made a new one to fit. The engine ran fine after that. However, the spinner is quite a bit heavier than a washer, and the outside edges are a lot farther away from the prop.
cruzomatic 02-21-2009 05:29 PM
If I purchase the washers online it will be $21.20 without shipping. That's a heck of a lot of money for a couple of washers. Just wasn't sure if I could get away with using some that were not quite OEM. I'll go see if they have something like them at the hardware store.
Thanks guys.
Ram Jet 02-21-2009 06:51 PM
ORIGINAL: cruzomatic
Thanks guys.
You know, I made a statement about using hardware store stainless washers that I would love to retract. Looking at my engine collection closely I noted that all of my factory original prop washers were machined, on a lathe?, to a particular profile. They could have been die cut from a piece of sheet metal at far less expense. The Japanese are very fugal people and not known to do something that isn't necessary. As a result I identified a used engine of mine that indeed has a "hardware store" washer on it that I now intend to replace.
$21.20 does seem a-bit over the top though.
Bill
Ken6PPC 02-21-2009 08:32 PM
Well, the $21.20 DOES include not only the washer, but also a prop nut and locking nut for both engines.
Personally, I would pay it, and try to not lose them again...
Ram Jet 02-21-2009 08:41 PM
ORIGINAL: Ken6PPC
That's more like it.
Bill
