OS 70 fs surpass need info
This is my first 4 stroke and i got this engine without an owners manual , could someone please guide me thru tuning this engine. i'm not sure which is the low speed adjustment screw, and will my 15% wildcat fuel work in this engine.
thanks for the help jr |
OS 70 fs
If you will send me your address, I will be happy to make a copy of my OS 70 instruction sheet and mail it to you.
Steve |
15% Wildcat will be fine.
The Surpass I has the low speed needle in the center of the throttle arm. The Surpass II has the H & L both on the same side. The HS is the one that is finger adjustable. The LS is the recessed one beside the HS that has a screw driver slot in it. |
You can download all the O.S. manuals at this site (in Adobe/Acrobat)
http://www.osengines.com/manuals/index.html |
RE: OS 70 fs surpass need info
Can someone please tell me what your HS needle setting is? I know this will vary with temp and altitude.. I am just curious. Mine seemed fine at 1 1/2 turns is this normal? I am hooking up a VP-20 because I could not get the tank exactly where I wanted it.. so I am having issues
Thanks and Happy New Year :) Nate |
1 1/4 to 1 1/2 turns is normal
Thank you so much.. I was getting nervous
Happy New Year Go Buckeyes!!!! Nate |
| All times are GMT -8. The time now is 11:04 AM. |
