Testor engine
I have a small tesor engine, I think it's a .049
It is new and never run. But I cant get it to start, where these BAD engines or ?? I hear it ignite but no more, I have taking it apart and it looks good. My cox's start first flip, even my norvel is a sweet engine, but this one is no fun at all. Thanks |
RE: Testor engine
Is it the reed valve version, or front rotor?
RE: Testor engine
They were notorious for hard starting
RE: Testor engine
ORIGINAL: w8ye They were notorious for hard starting |
RE: Testor engine
I only had Cox planes. My friends never had luck getting their Testors plastic control line planes started. I don't recall whether they came with spring starters are not. We didn't know what electric starters were back then. They probably didn't make them in 1/2A size anyway.
Tom |
RE: Testor engine
It is a reed valve, with a plasic reed.
Thanks |
RE: Testor engine
Hi!
Does it have a white plastic tank and spring starter? |
RE: Testor engine
If it just sort of makes a light pop but never runs, the reed valve is not seating.
See if you can turn the reed around to the other side so maybe it will seal |
RE: Testor engine
Jaka yes it is.
w8ye, I will try that. Thanks. |
RE: Testor engine
If you have any more trouble just contact me. I have a few of these engines.
RE: Testor engine
I had one of these when I was a kid. The only way it would start was to first prime it with a little fuel put in thruogh the exhaust port. One started it ran real well, however the plastic plane it was in wouldn't fly.
bhady |
RE: Testor engine
1 Attachment(s)
These are the ones I like.
| All times are GMT -8. The time now is 09:01 PM. |
