RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Mds .58 (https://www.rcuniverse.com/forum/glow-engines-114/86870-mds-58-a.html)
Pepito 03-25-2002 09:20 PM
Mds .58
I have an MDS .58 with a very sensitive high speed needle. It is very difficult to adjust and it ends up running very hot about 300 degrees F !!!!).
If you richen or lean the high end just a little bit then it quits. It is also very sensitive to attitude changes. For example, when you raise the model's nose, the engine goes noticeably leaner and when you lower model to point straight down it is way richer.
On my other models this happens when the engine is going lean. However, this thing will not let me richen the mix, it starts burbling and quits!
I have changed the plug, disassembled and cleaned the carb, changed the fuel tank plumbing, ..........
Any ideas??
Homebrewer 03-25-2002 10:26 PM
MDS .58
Mine runs like a swiss watch. Two things may be causing this problem:
1. Muffler, you should have a MKII muffler which provides better backpressure to the engine than the original muffler. If your engine was bought new within the last 15 months, you should have the MKII muffler already.
2. Nitro content and plug. Use no more than 5% nitro, use a cheap fox idle bar plug and try again.
Both suggestions are given assuming the rest of your fuel system/setup is properly setup, i.e. fuel tank not too far back, no leaks in fuel lines, tank height is appropriate, the carb o-ring is on the bottom of the carb throat, not seated at the base like 99.9% of engines (check this first, check for pinched o-ring and reseat carb and o-ring but also put a little silicon gel on base of carb as a precaution).
By the way, 300 degrees F temp reading taken at glowplug location is not too hot, You should be at 350 degrees F for best performance but not to exceed 400 degrees F.
Pepito 03-25-2002 10:58 PM
Thanks Homebrewer
I'll try the plug/nitro suggestion. Right now i am using 10% Omega and O.S. #8 plug.
I thought that 220-240 degrees F was normal. Now i am not too worried.
Thanks!
