RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   measuring compression (https://www.rcuniverse.com/forum/glow-engines-114/9021407-measuring-compression.html)
IllegalAlien 08-16-2009 08:25 PM
Is there a tool to check compression on a motor.
I have an OS .91 and It feels like it has low compression, but I am just not sure.
w8ye 08-16-2009 08:43 PM
RE: measuring compression
I use the Armstrong gauge for measuring compression.
It is a relative measure compared to other engines or the same engine in the past
Motorboy 08-17-2009 12:10 AM
ORIGINAL: IllegalAlien
If it is a ringed engine, it can feel like it has low compression, in case your engine are a 4 stroke engine keep the trottle barrel open then compression feel better when you are testing compression.
But important of all: are the engine running well in idling and no trouble in trottling = compression are ok.
I never had a compression tester to measure compression in my engines. ;)
Edit: missing text..
