RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Tank position problem. (https://www.rcuniverse.com/forum/glow-engines-114/9048222-tank-position-problem.html)
James c harrell 08-26-2009 09:45 PM
I have a problem with one of my planes that I think can be blamed on the fact that the tank sits lower than the engine. I have been told that the clunk should be level with carb. On mine the clunk sits about 3 inches below the carb. Maybe even more than that. The problem with it is that when ever I pull any tight manuver or a "hard G" the engine will die or starve out. Also I seem to have mixtures that are never the same. It seems to change tune, sometimes in mid-flight.If, in fact, I am right about this being my problem, will a pump fix the problem? I have a Perry VP-20 pump that I used on another plane with great results. I have changed engines from a Royal 46 with a perry carb to a MDS-48 with the stock carb. They both do the same thing but the MDS does it a whole lot worse. I think that comes from the difference between a two needle carb and a air bleed carb. Any advice would be appreciated. This is getting real irritateing but I think I am about to perfect the dead-stick landing!
jessiej 08-26-2009 10:33 PM
RE: Tank position problem.
The general rule of thumb is that the center line of the tank (not the clunk) should be level with or slightly below the spray bar of the carb.
jess
spaceworm 08-27-2009 07:35 AM
Another "general rule of thumb" is for the top of the tank to be level with, or three-eighths (3/8) inch above the spray bar. I would think a pump would help here, but can't advise which one. Are you using muffler pressure?
Sport_Pilot 08-27-2009 07:46 AM
Actually unless using uniflow the center of the tank should be 1/4" to 1/2" below the spraybar. This is for a 60 sized plane and needs to be larger or smaller depending on the size of the engine and tank.
mandtra 08-27-2009 08:29 AM
i never have had a problem with the tank being too LOW . my problems have always when the tank is too HIGH. (fuel drips) I think it's more than the tank is too low . I agree it sounds like a fuel delivery problem , but there are MANY things that can cause that problem
Trisquire 08-27-2009 10:20 AM
ORIGINAL: Sport_Pilot
Actually unless using uniflow the center of the tank should be 1/4'' to 1/2'' below the spraybar. This is for a 60 sized plane and needs to be larger or smaller depending on the size of the engine and tank.
I've never understood that. Don't you want the center of the tank in line with the spray bar, so you get the same fuel mixture when the plane is upright or inverted?
Tom
TedMo 08-27-2009 10:51 AM
Tom what you say makes sense but doesn't actually hold true. Almost without exception better fuel draw occurs when tank is lower than spray bar, Definitly more problems occur when tank high. Guess reason here is tank is pressurized from muffler therefore maintains good flow at all attitudes. Inverted engines of all types often have problems due to tank too high. Tank location in his case is it's far too low for good fuel draw. He could raise tank or use a pump.
Sport_Pilot 08-27-2009 12:50 PM
Don't you want the center of the tank in line with the spray bar, so you get the same fuel mixture when the plane is upright or inverted? [/quote]
You won't get the same fuel mixture, it will be leaner when upside down. When right side up the clunk is at the bottom and vent at the top, there is no restriction to the vent. Imagine pressure as inch's of fuel. The clunk is at the bottom and the spray bar is at the center lets use a round number for muffler pressure of 10 inchs of fuel, that is a bit low but it is very round. Lets pretend the tank is 4" deep from top to bottom. So when the plane is upright the tank pressure is the same as the muffler pressure because of the unrestricted vent and the fuel pressure is 10"of muffler pressure plus the 4" of fuel on the clunk minus the 2 inches from the spray bar to the clunk which comes to 12". Now when upside down the vent is at the bottom and is now restricted by the fuel in the tank, so the tank pressure is now the 10" of muffler pressure minus the 4" of fuel in the tank or 8". So the fuel pressure is 8" + 4" - 2" = 10" so the engine will run slightly leaner because the fuel pressure is lower. In this case the best location would be 1" below the spray bar. Then when upright the pressure would be 10" of tank pressure + 4" from top of fuel to clunk - 3" from clunk or 11". When upside down the pressure would be 8" + 4" - 1" or 11" which is the same pressure. Actually the rule of thumb should be that 1/4 of the tank should be above the spraybar, but 1/2" is close enough for most installations. In fact even centered is often not noticeable.
RVman 08-27-2009 02:25 PM
Doubt the problem is where the tank is located. The engines run fine pointed vertical when the tank is is 8" below the carb...people here make alot of fuss about tank position for some reason? However 3" low when the plane is level is a lot and probably richens the engine when inverted but it shouldn't cause the engine to quit. I'd look for bad fuel lines or crap in the carb, maybe try tuning a little richer..
Trisquire 08-27-2009 03:30 PM
I got it. Thanks Sport Pilot.
Tom
Jim Thomerson 08-27-2009 03:44 PM
It is not uncommon for people flying control line precision aerobatics to move a tank up or down the thickness of a playing card.
James c harrell 08-27-2009 03:50 PM
I think I can relate too. I am going to look further in the direction of bad lines or crap in my clunk. Man there is nothing worse than crap in your clunk. Problem is that I had a problem with weak gear and beefed up the mount to the gear. Gear is real solid now but you ain't getting that tank out without a saw! Oh well. Sure hope I find something in there. Seems like I remember there being a filter in the clunk and my dad said that back in the day they had alot of problems with that type of clunk stopping up. When you would refill it would clear it untill you pulled fuel back through in flight. Thus giving you a "wandering fuel mixture". Well it sounds like a good explanation any-way. I'll let you know what happens. Thanx guys
Trisquire 08-27-2009 05:04 PM
I wonder if engines are more tolerant of the tank position with (Tettra/Jett) bubbless tanks. Pylon racing enthusiasts seem to be the only ones using them. I'm guessing it's probably best to line bubbless tanks up with the spray bar.
Tom
James c harrell 08-28-2009 12:33 AM
Well I am at a loss now. I finally got my tank out and went in just knowing I was going to see my problem. I can't see any thing wrong at all. No holes in the lines, no screen in the clunk, tank is perfectly clean, all lines are where they should be. The tank can only go one place and in one position. The plane is a Fun-World 40 made by World Models. I just can't beleive they designed it wrong so I will leave the position as is. Other than that newly designed acess hatch I just cut in it. I will, I think, try the Perry VP- 20 pump on it. Back to asking questions again. Old school one here. Vent up, clunk down, fill tube down. Someone tell me I got that right. By the way, I put a vacum pump on it. Plugged the other lines and it is still holding 20 pounds after 30 minutes. Any one got any ideas? I don't have much hair left and it is getting thinner by the minute.
anuthabubba 08-28-2009 02:06 PM
"I just can't beleive they designed it wrong ... so I will leave the position as is."
Believe it. It will function flying straight and level so it does 'work'. It just is not positioned optimally.
Terry in LP
jessiej 08-28-2009 03:31 PM
ORIGINAL: James c harrell
Quite a few ARFs suffer from improper tank positon.
jess
James c harrell 08-28-2009 09:24 PM
I can believe they did now but don't know what to do about it. the tank is at the upper part of the fuse but the engine is even higher. It didn't look centered when I put it together but it had to go on the mark to line up with the cowling. If in fact that is the problem, using a pump should solve the problem right? I think I'll try it but uf it still screws up I am going to a four-stroke. From what I have seen they tend to pull fuel better and run a little more consistant. HOPEFULLY
freakingfast 08-28-2009 10:38 PM
WM did set that engine high. Can you rotate the engine and get a new cowling. Complain (nicely) to WM in Livermore CA, I bet they send you a new one if they have one. They like happy costumers.
DarZeelon 08-29-2009 01:07 AM
James,
As some already wrote, the correct level for the fuel-tank, is so its center-line is at the same level as the nozzle in the carburettor.
Hugh (Sport Pilot) wrote, that it should be mounted a bit lower, to compensate for the vent location (the vent being 'in the drink', when the model is inverted)...
This is true, but the effect of 2-3", or so, of fuel above the vent, with the tank full, becomes less and less significant, as the fuel is used up during flight.
Eventualy, as your plane comes in for an 'inverted landing'; nose high and tank nearly empty, the vent tube will no longer be submerged in fuel...
If you just abide by the simple center-line - nozzle relationship, portrayed in the first line of this post, you'll be alright.
The problem is that most kit and ARF manufacturers, seem not to intend for the model to actually fly... They instruct the builder/owner to place the fuel-tank, nowhere near to where this relationship will be maintained... I began [link=http://www.rcuniverse.com/forum/m_4960623/anchors_4960623/mpage_1/tm.htm#4960623]a thread about this[/link], over two years ago.
It is up to you to 'remodel' the fuel-tank compartment and/or the engine's mounting, to acheive this objective and for your engine to run right...
Trisquire 08-29-2009 04:18 AM
This subject came up in a Clarence Mather column once. The reader asked (and I'm paraphrasing), "Why don't kit manufacturers take the proper engine/tank relationship into account?"
Clarence's response was something like, "Kit manufacturers know planes; they don't necessarily know engines."
Tom
James c harrell 08-29-2009 11:55 AM
I can relate to the manufacturers not being worried about tank position. My problem was indeed tank being lower, about 4-5inches , carb to clunk. I thought about inverting the engine but I am not a big fan of inverted engines so I put a perry pump on it and problen is solved. I only have a slight transistion problem thqt I think I can solve by tweaking out the pump pressure. I did like the idea that freakingfast had when he said to write World Models and get a new cowling but not for a new cowling but to let them know that we as the consumer would like a little more attention to this problem in the first place. If I had to find something good about this whole ordeal it would have to be that I think I can dead-stick one down better than any-one else in my club. Practice makes perfect!
DarZeelon 08-29-2009 02:18 PM
...My problem was indeed tank being lower, about 4-5inches , carb to clunk.
James,
You're making that incorrect assumption again... and missing the point.
It does not matter how high the clunk in your fuel-tank is!
The only thing that matters is the level of the fuel.
This is the reason people tell you to set the tank, so its center-line is at the same level as the carburettor's nozzle.
...And no-one but you even mentions the clunk...
Suppose the clunk is all the way at the bottom of a 4.5' tall barrel (with a large enough diameter fuel-line that would not impede flow), filled almost to the brim with fuel, to which the engine is mounted. As long as the level of the fuel is no higher than 2" above the carburettor's nozzle, to no lower than 2" lower than the same; the engine will get a reliable fuel-delivery.
Pascal's Law determines that all that matters is the level of the fuel.
So, if you set the average level (the tank's center-line), to the same level as the fuel's point of entry into the engine, you will get the minimum variation in the amount of fuel delivered, at each throttle setting.
Motorboy 08-29-2009 02:37 PM
1 Attachment(s)
The pic are copied from instruction manual, the pic tell more than 1000 word. ;) See in the pic how the tank are placed in right height with the spraybar in the carburator.
DarZeelon 08-29-2009 03:16 PM
Jens,
The photo you posted is from the manual for the OS LA engine...
Probably because this engine targets modelers' first plane (usually their trainers), even the line drawn does not coincide with the spray-bar (it is higher than it is), but it also places the tank's center-line about 3/8-1/2" below the level of the nozzle.
This is not that critical for a model that would probably spend no more than 1-2% of its flight time inverted (and then it would richen-up a bit).
I still think the same practice of 'tank center-line at nozzle level', should be applied to first planes too...
Trisquire 08-29-2009 03:54 PM
1 Attachment(s)
A little closer:
Motorboy 08-29-2009 04:01 PM
ORIGINAL: Trisquire
A little closer:
There are common in aerobatic plane, 3D etc.. but if your engine are flooded by fuel (siphoning fuel into engine), move the tank a bit lower.
Sport_Pilot 08-29-2009 05:34 PM
IMO the diagram puts the tank at just the right position.
Trisquire 08-29-2009 06:42 PM
1 Attachment(s)
On a typical upright engine installation, it's a bit of a challenge getting the tank high enough. If it was me, I would just let the tank peek out the top of the fuselage. Not pretty, but functional.
Motorboy 08-30-2009 12:43 AM
ORIGINAL: Trisquire
The alternative: mount the engine horizontal and the carburator will be lowered, then the tank installation will be placed in right height to main needle.
But most generally: Follow the building construction/plan of aircraft where the engine and tank will be placed in right place.
Some time the tank are in the kit of model airplane, and follow instruction where the tank are placed.
DarZeelon 08-30-2009 01:07 AM
ORIGINAL: Motorboy
Jens,
This is the exact problem!
Most kits and nearly all ARFs, that have the engine mounted upright (or inverted), DO NOT place the fuel-tank at the proper level.
This is a fact.
If the engine is upright, the fuel-tank will most likely be lower than ideal!
If such a model is built according to plans, or in an ARF, according to the instructions; when the plane is flown inverted, the engine will be running significanly richer than it ran when the plane was right-side-up... This is because the instructions/plans tell the builder/assembler to mount the engine too high!
With the holes already drilled in the firewall, there is not much of a choice.
And as to the large hole in the firewall, for the fuel-tubing (in which most normal tanks' 'snout' fits); it is always located behind the crankshaft center-line; not behind the carburettor...
This means it is about 40 mm (1.5" ) too low...
Motorboy 08-30-2009 01:34 AM
ORIGINAL: DarZeelon
ORIGINAL: Motorboy
Jens,
This is a fact.
This means it is about 40 mm (1.5'' ) too low...
I do not had problems with the motor by tank positions recommended by instructions and plans.
Have not experienced the problem with the Kyosho modelairplane (Messerscmitt BF-190 and PT-17 biplane).
It's not every day we read about problems tank placement in the forum. How many have ARF model airplanes in total, and rare to complaint about the tank location. It depends on the tank and engine placement is critical to the flight characteristics and engine setting for some model airplane and engines who are sensitive by fuel mixture in relating to the tank location.
The second problem may come if a switch from 2 stroke engines to 4 stroke engine or vice versa and get problem without repositioning the tank to right height again because the height of carburetor is quite difference in the 2 - and 4 stroke engines.
The last problem are length between engine and tank who make more lean (climbing) or rich (sinking) fuelmix.
jaka 08-30-2009 07:05 AM
1 Attachment(s)
Hi!
Tank position is a big problem if you mount the engine up-right!
A much better position is to mount it sideways.
Trisquire 08-30-2009 07:40 AM
1 Attachment(s)
If you're committed to an upright installation, because the holes have already been drilled, etc. Another alternative, is to simply heighten the fuselage above the tank somewhat. Once again, not necessarily attractive, but it solves the problem:
James c harrell 08-30-2009 07:46 AM
I kinda like the sideways mount too. Even more now that I have seen how important tank position can be. Would have been nice for WM to have pointed this out in the instructions befor I cut me cowling like the book said. But I guess if you learn something from it the mistake was worth it. Just a note for models makers. look at the Aeroworks Edge 540. They not only went with sideways, they put a diagonal slant to fit the cowl without alot of bucthering. They even offered options for other mounts with engine and tank aligned in all of them. I call that quality in a kit, even an ARF.
turbo.gst 08-30-2009 01:43 PM
I have found side mounting an engine makes getting the tank / engine setup very quick and easy. The result makes for a dependable and powerful setup as it will hold a setting for the entire tank. I know you have seen alot of ideas. I hope you can find a system that works well for you. I know I tried several before I was truely happy. Good luck in your search......
turbo
