RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   A small problem concerning backplate help needed. (https://www.rcuniverse.com/forum/glow-engines-114/936252-small-problem-concerning-backplate-help-needed.html)
faisalk 07-08-2003 08:28 AM
I have an os46 fx engine. There are a total of 4 screws to connect the back plate to the engine body. Problem is that One screw does not tighten because the threadness on the hole(the one in engine body) is gone. I know I can buy spare screws and back plate but problem is in engine body. Is it ok to run the engine with only 3 screws on? if not anyway I can fix it?
VecoRacer 07-08-2003 09:07 AM
It's better if you repair it, or you can maybe try try to get some liquid metal paste and put that in the hole, then put the screw in. when it's dry you can unscrew the screw and put the backplate on again. don't know if this works, but you can always try.
does the screw got any grip in there? or is it so loose it falls out?
when it's got any grip at all, you can try tapping new threads in the screwhole.
bob_nj 07-08-2003 09:10 AM
Tap, Tap, Tap
Can you tap it to the closest american size?
faisalk 07-08-2003 09:13 AM
What you mean by tapping it to closest american size? I am sorry im a little dumb here.
DarZeelon 07-08-2003 10:05 AM
Tap-tap
Faisalk,
A tap is a tool used to create an internal thread in a hole, so a bolt turned into that hole will engage and hold.
What you were told is to get a larger tap - not too big for the housing, to clean out the remains of the old threads and to make a new, clean, one-size-larger thread.
When going to a hardware store, or a metal machining factory, you should take the engine crankcase and the old backplate bolt.
It is advisable to use a tap with a larger diameter, but the same pitch. I.e. if the bolt is 3mm-x0.5, tap the hole 4mm-x0.5.
You will need to use the correct bolt in that hole, not the original piece.
An alternative, cheaper fix is to use JB-Weld in the hole.
If the bolt is not tightened to strongly, it could hold.
In the future, be careful not to cross-thread the bolt and not to overtighten it.
Sincerely,
faisalk 07-08-2003 10:11 AM
hMMMM. Can I run the engine with only 3 screws on? It seems to be running fine uptil now.
DarZeelon 07-08-2003 10:15 AM
A screw loose..
Faisalk,
If the engine manufacturer though 3 bolts at 3 of the 4 corners are enough, he would not have added the fourth...
The bolt also holds the integrity of the crankcase...
For a short time it may run OK, but I would advise against it.
Fix it as soon as possible.
big max 1935 07-08-2003 02:14 PM
I have two ways I have repaired engines with this problem. The first is just get a longer screw, you can measure the depth of the hole to see what you need , just be care full & don't over tighten . The other I have used is to find a much longer bolt with a nut on it , screw the bolt in until it bottoms out then tighten the nut down on your back cover, cut off the excess bolt. The manufactures have more threads in hole than they have bolt length, these have worked every time for me . Good luck MAX H.
downunder-RCU 07-09-2003 12:40 AM
So long as there are no leaks then you should be fine with just 3 screws. Be aware though that any screw hole that goes into the crankcase MUST be sealed.
I have my doubts that the backplate adds much integrity to the crankcase when you consider the engines that use a plastic backplate (I think even Irvine uses them).
Gizmo-RCU 07-09-2003 12:49 AM
engines
Following your threads I'm glad not to be one of your engines, QUIT FIDDLING AROUND WITH THEM AND GET HELP FROM EXPERIENCED PEOPLE!!!!!!!
elmote 07-09-2003 05:58 AM
Give him a break
Maybe not the brightest candle on the cake, but give the man a break! Look where he hails from. He is NOT going to find a club full of friendly helpful flyers around the corner from the bazzare anywhere in Pakistan. He's doing the best he can with the resources he has, which by-in-large, means this forum.
Elmo Te
Gizmo-RCU 07-09-2003 12:18 PM
Sorry
You are right to a point about giving a break. I do feel that the poor guy needs help and some of that is advice on how not to destroy good equipment. Given time he will no doubt know a lot about engines from all of his experiences both good or bad.
BillHarris 07-09-2003 01:02 PM
Look where he hails from. He is NOT going to find a club full of friendly helpful flyers around the corner...
He was advised of a local club in April:
There is a large club just outside Karachi, in place called Korangi Creek.
The club is just before you get the Airforce base.
Been there once whilst on a visit to Karachi on Business. Loads of flyers.
Don't know of any shops, however, if you get to the field, i am sure someone could help you, they are a friendly bunch.
__________________
DJ Gadget
Click here to visit the Dubai Radio Control Club website
big max 1935 07-09-2003 02:12 PM
His help may be 20 miles away & that may be a long way on a bicycle. He's just learning the hard way , hope he & the engines survive!
MAX H.
faisalk 07-09-2003 04:59 PM
Guys its not that bad out here. You guys still think that we drive on bicycles and theres no electricity :) seriously I was in Usa for 3 years for studies and half of the Americans didnt know where Pakistan is and half of them thought that Pakistan doesnt even have electricity :) Well its not that bad out here. Agreed we are far behind than USA but we do have cars,electricity,Mcdonalds,Pizza Hut etc. A Mercedes S class here costs around $150000(lot of duties) and there are more here than ive ever seen in my 3 yrs in boston(trust me)
Bax 07-09-2003 07:11 PM
FaisalK,
If the hole is just stripped, you can likely use a slightly-longer bolt of the same diameter. There shoule be good threads slightly deeper. The O.S. Max .46 FX uses M3x8 screws for the rear cover. A longer 3mm screw would work, as long as it does not hit the bottom of the bolt hole. Just carefully tighten it and you'll be fine.
Flying Tivo 07-09-2003 08:15 PM
Boy, do I feel your pain?
FaisalK:
Im still driving my 3rd Generation Burro, with Mag horseshoes with 3D thread, running on a 3.2Liter powered by water and extremly long green grass. It only gives me 2 kilometers a gallon but it is the best around here.(Mexico). OOOOOppppsss, forgot tu mention my exclusive FOX boots, which enhances the feel of the road.
Viva Mexico!!!!!!!!!!!!!!!!!!!!!!!!!!!
:D :D :D :D :D :D
ZM2000 07-10-2003 06:34 AM
Quote
Unquote
Elmot & FaisalK
Perhaps you have not seen one of my previous post that I repeat here:
"FaisalK
For your information there is an aeromodelling club in Karachi called M.A.S.K. and many
experienced modellers regularly fly glow, gas and jet planes on Sundays near Korangi
Creek Base. Some of them have held National and International titles. Instructors are
available and flying competency certificates are also issued on behalf of BMFA, U.K. by
their resident examiner.
If you need further info or help for your engine please contact Zahid at 5851646."
