RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Stackable Multi-Cylinder Glow Driver (https://www.rcuniverse.com/forum/glow-engines-114/9412346-stackable-multi-cylinder-glow-driver.html)
01sporty 01-13-2010 12:12 PM
1 Attachment(s)
I modified an existing glow driver circuit to accommodate multiple cylinders. Lots of details available to anyone that might be interested.
Patxipt 01-13-2010 12:56 PM
RE: Stackable Multi-Cylinder Glow Driver
Count me in!
That looks terribly sweet![8D]
Campgems 01-13-2010 05:31 PM
MeTo
Don
01sporty 01-13-2010 06:48 PM
1 Attachment(s)
OK, here's the original circuit: [link]http://www.sentex.net/~mec1995/gadgets/glow.htm[/link]
This guy modified it replace Q1 and Q2 with a single mosfet. [link]http://www.webx.dk/rc/glow/glow.htm[/link] He also added a voltage regulator to keep the glow from dimming from the starter drain and/or a low battery condition.
For multi-cylinder use, I decided amp meters would just get in the way so I eliminated it. The author in the second link thought the power resistor (RM) was important so I kept it but moved it to the minus rail which left the positive rail completely bare to become the common.
I also added an indicator LED in series with RM for a visual on any burned out plugs or bad connections. This changed the value of Rm from .2 to .6 ohm. The plug completes the circuit so if the LED isn't lit, something is amiss.
I also knew that I would always be using the same type glow plug so I only used the 100k pot long enough to determine the needed value, then replaced it with a 1/8 watt, fixed value resister. For my plug that value came out to 10k. Use a lower value to produce a hotter glow and a higher value for colder. If all the same components were used, you could probably just swap fixed value resisters until you get the glow you like on your particular plug.
I cut the board on a little cnc I built but the layout should lend itself equally well to etching. PDF1 is the toolpath and hole layout. I use a V cutter set to give a .015 width. PDF2 shows the component layout. This is available as a cad file to anyone that would like to send me an email addy.
This is the first time I'd worked with surface mount components. After a little practice, I really like them. I do think I would have went with a larger size IC1 if I had it to do over. It was pretty challenging. Fortunately, they are really cheap. You might want to get a couple of extra.
This link should take you to the Mouser Project list. [link]http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=87d937f999[/link] It should be correct. The C6 caps that I got were supposed to be long lead and came in with short lead so I had to add to the leads. I changed the part number to another cap but never ordered one so that's a bit of a wild card. The list does not contain the 1/8 watt resisters R220 and R10K.
I'll try to get a couple of closeups of the construction later.
Cheers,
Walt
volarealsur 12-10-2014 03:47 PM
Hello
Does anyone have the CAD files of the PCB board?
I really appreciate, just to save some work, I plan to use my CnC router machine to make the boards.
Jorge
coriolan 12-12-2014 01:00 PM
Its a very simple layout,should not too hard to develop your own file. Here is the actual schematic:
http://www.sentex.ca/~mec1995/gadgets/glow.htm
