RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Engine Temps (https://www.rcuniverse.com/forum/glow-engines-114/9455879-engine-temps.html)
BP5589 01-28-2010 01:41 PM
Engine Temps
Hello,
I am running a Saito 182 Twin on a test stand and the head temps are about 8 degrees different. Does this sound normal?
Thanks, Bill
gkamysz 01-28-2010 02:01 PM
RE: Engine Temps
8° is nothing to worry about.
w8ye 01-28-2010 02:06 PM
RE: Engine Temps
The 182 is a twin carburettor engine. you may have one mixture a little different
If you are using a IR gun, you may not be hitting the same spot on both cylinders?
Also, the glow plug is higher on the left cylinder than it is on the right cylinder. This could make a slight difference.
In reality, the resolution of your temp gun is probably more than the difference you are reading so you may actually be chasing your tail.
8 degrees is nothing.
pe reivers 01-28-2010 05:26 PM
RE: Engine Temps
8 degrees is not much. If it gets more, fit a hotter plug to the hot cylinder.
BP5589 01-28-2010 06:00 PM
RE: Engine Temps
Thank you, all.
Bill
