RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   fox 50 is back (https://www.rcuniverse.com/forum/glow-engines-114/9619220-fox-50-back.html)
AMB 03-28-2010 05:26 PM
fox 50 is back
fox is (or is gearing up) to re-release the FOX 50, nice, made in the USA no OEM parts China or wherever from
Hobbsy was talking to Sharon at Fox and just found this out martin
sweet engine have one with a Davis diesel head
controlliner 03-28-2010 06:53 PM
RE: fox 50 is back
:D:D:D:D:DI may get one again. My last one would pull a barn full of livestock.
Hobbsy 03-28-2010 07:38 PM
RE: fox 50 is back
Woops Martin, I need to apologise to you and others, this came from Broken Wings, I did not intend to take credit for stumbling across it, I'm just glad to hear it. I'll re-phrase in the Diesel forum.
AMB 03-28-2010 08:18 PM
RE: fox 50 is back
Hobbsy thanks for giving him credit but the important thing ITS BACK martin
Broken Wings 03-28-2010 09:34 PM
RE: fox 50 is back
I got it from someone else.....:D
I'm just glad we can purchase the 50 again.
WhiteRook 03-30-2010 10:38 AM
RE: fox 50 is back
i have two fox .50's , i was thinking of trying one in a 68 inch 9 pound plane, you think it would pull it good enough?
controlliner 03-30-2010 11:46 AM
RE: fox 50 is back
ORIGINAL: WhiteRook
In a word, Yes. This engine has the power of a .60 in my opinion. As long as you don't expect to do 3D flight with this plane. This engine will except a wide range of props anywhere from Sport performance right up to exterme fast aircraft. One word of advice though, The company fits the ringed aluminum piston tighter than most other companies dare to, so use castor oil in your fuel to prevent piston galling. I forgot to add this, my Fox .50 pulled over my test stand during running in and fine tuning the carb. Aslo I have used 0% nitro fuel in this engine and it still made bags of thrust[X(]
MJD 03-30-2010 12:17 PM
RE: fox 50 is back
How fast will they turn a 10-6 APC?
MJD
earlwb 03-30-2010 01:38 PM
RE: fox 50 is back
ORIGINAL: MJD
MJD
Actually the .50 isn't designed to turn small props fast. It is designed to turn larger props faster than the smaller displacement engines can.
The .50 being a bored out .45 tends to be flow restricted due to the shallower inlet ports, so it doesn't breathe as well at higher rpms.
But it'll turn a larger prop better than the smaller engines can. The additional displacement helps there.
But as I remember it right, the .50 could turn a 10x6 at about 500 rpms more than a 45 could.
Where it winds up being good is like for a large 40 size scale plane where you want some extra oomph. Or a 40 size 3D plane where you want more vertical performance out of it.
The .50 is able to turn a 11x7 prop pretty well. The 11x7 prop used to be what we used on all the big .60's years ago.
The .40's back then used 10x6 props or maybe a 11x5 or 11x6 sometimes.
AMB 03-30-2010 02:40 PM
RE: fox 50 is back
If you go to the diesel site FOX 50 (these are new posts) you can see the rpm numbers on the Fox 50 remember as a diesel it will turn a larger prop than on
glow so I guess you have to knock off a inch in prop diameter to get close on these numbers
martin
Sport_Pilot 03-30-2010 02:46 PM
RE: fox 50 is back
I think both the Fox .50 and the .47 would turn a 10-6 at 14,700 RPM, but the .50 probably does a bit better on larger props.
controlliner 03-30-2010 03:21 PM
RE: fox 50 is back
The owner's manual quotes 14,500 RPM on a 10X6. The engine is better suited as a stump puller (it's just timed that way)
Hobbsy 03-30-2010 03:27 PM
RE: fox 50 is back
The .50 has the same .905 bore as the Eagle .60 but the Eagle has a .937 stroke.
scott17 03-30-2010 05:47 PM
RE: fox 50 is back
Just out of curiosity, how would it compare to an OS 50 SX????
controlliner 03-31-2010 08:13 AM
RE: fox 50 is back
ORIGINAL: scott17
It is hard to say, OS is known to over inflate their engine's actual RPM figures and BHP rating:eek:. I believe the Fox will outlast the OS and parts are way cheaper. If Fox puts this engine out with an AAO piston and liner, It will be a Barn Burner.:D
blw 03-31-2010 09:34 AM
RE: fox 50 is back
The 50SX was a pretty good engine. The Evolution 52NX was even better as far as power. I've flown both engines on the same model.
