Evolution .46 muffler screw needed
Does anyone know the size of the long muffler screw that holds the two parts together for a Evolution .46? I need a new one and I cant find the size. I was going to place an order with Tower hopping they would have one.
RE: Evolution .46 muffler screw needed
Steve,
Don't bother to search for 'proprietary R/C model' bolts... Tower will live long even if you don't buy two bolts from them; and have them shipped. These muffler bolts are rather simple, M3.0 x .5, or M3.5 x .6 items, which your local hardware supply could practically give away... Just take the muffler and one of the old bolts with you, to make sure you get the proper metric thread and length. Oxide coated, galvanized, or stainless ones will last longer; without corroding, or becoming stuck. |
The one I'm looking for is about 140mm long, my hardware store does not have any like that.
OOPS!
So, that is not the 'muffler attachment bolts', but the long screw that holds the whole thing together... I answered automatically... You can probably get a small diameter threaded rod, with appropriate lock-nuts and washers, at the same hardware supply... Tower does not seem to list spare parts/components for this muffler, so you're pretty much on your own. |
Tell you what works better than finding an exact match, and will work a lot better than the original bolt:
Get a Length of fully Treaded 6-32 rod & 2 6-32 Lock Nuts or Nylon Insert Lock Nuts(Nylocks) Cut it 1/2' to 3/4" longer than the length of the silencer/muffler Drill out the holes on both ends of the Muffler the same diameter as the Rod Screw onto one end of the rod one of the Locknuts Insert the Rod through the Muffler Screw on the other Locknut Snug down the Locknuts and your done Gauranteed not to come apart, I use this method on my Pylon and Combat planes, I can't afford to have the Mufflers come apart in the middle of a Heat. |
That's a good idea.
The threaded rod is an excellent idea. Cheap and quick.
ORIGINAL: DarZeelon OOPS! So, that is not the 'muffler attachment bolts', but the long screw that holds the whole thing together... I answered automatically... You can probably get a small diameter threaded rod, with appropriate lock-nuts and washers, at the same hardware supply... Tower does not seem to list spare parts/components for this muffler, so you're pretty much on your own. EVOLUTION IS HORIZON HOBBYS PRODUCT, NOT TOWER HOBBIES.[X(] |
I know but I'm placing an order with tower not HH. |
ORIGINAL: MOTORMAN37 Evolution is Horizon Hobby's product, not Tower Hobbies'.[X(] But there is no parts breakdown for [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EVO100601]the Evolution item[/link] either... |
We all knew what you meant; no problem.
The user manual just shows it as the entire muffler assembly. You can probably find all the hardware at a hobby shop if you are near one. |
Im going to try the Treaded 6-32 rod & 2 6-32 Lock Nuts.
ORIGINAL: smkrcflyer Im going to try the Treaded 6-32 rod & 2 6-32 Lock Nuts. Do yourself a favor, and clean it good, and assemble it with some HIGH TEMP RTV (silocone). It should stay together forever, and not rotate than. You can get "Aluminum colored" which you canot even see when it is applied.:D This is a trick that is used on Tower Hobbies mufflers to keep them together.:D |
ORIGINAL: DarZeelon ORIGINAL: MOTORMAN37 Evolution is Horizon Hobby's product, not Tower Hobbies'.[X(] But there is no parts breakdown for [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EVO100601]the Evolution item[/link] either... I was just giving you a hard time.:D Dave |
If you don't have RTV on hand, just get a little epoxy in the threads and it will hold the nuts tight on each end as long as you want. I don't even bother to seal the muffler halves anymore.
An altogether better solution if you are placing an order with Tower is to spring $14 for the Tower 46 muffler. Better performance and cheap! It will work wonders for your Evolution 46.
got one of these mufflers in my junk....errrrr spare parts box
ORIGINAL: scott17 An altogether better solution if you are placing an order with Tower is to spring $14 for the Tower 46 muffler. Better performance and cheap! It will work wonders for your Evolution 46. |
| All times are GMT -8. The time now is 12:45 PM. |
