RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   I need Help! How do you get a remote glow off of a plug? (https://www.rcuniverse.com/forum/glow-engines-114/9708667-i-need-help-how-do-you-get-remote-glow-off-plug.html)
Nick Hudson 05-03-2010 10:29 PM
Have a engine that has a Ace remote glow and I need to take off the engine but can't get the stupid connectors off the glow plugs, I'm stupid, how do they come off?
w8ye 05-03-2010 10:52 PM
RE: I need Help! How do you get a remote glow off of a plug?
Put a picture up here for us
MetallicaJunkie 05-03-2010 11:17 PM
maybe you need to get a pair of needle nose pliers press down and turn...kinda like those twist and lock Mcdaniels style ignitors
proptop 05-04-2010 12:44 AM
You should be able to remove it by pushing in and turning counter-clockwise about a quarter turn?
What manuf. engine are you talking about?
Iflyglow 05-04-2010 10:26 AM
1 Attachment(s)
If it uses the McDanial style, they can be a real bear some times. I have had them break on YS 1.10's because you could not grip it good enough to twist it hard engough (not enough clearance to grip it with a needle nose) and the wire would pull out. This is the solution I have found, and it works like no other.
It is the connector that most pattern flyers use, and it iwll never vibrate loose, or have a bad contact, and it is easy to remove. It is machined out of brass to fit OS and YS plugs.
The link that I provided shows the one I am mentioning, and the other styles that you can maybe use to identify yours.
http://www.centralhobbies.com/glow/headlock.htm
goirish 05-04-2010 10:38 AM
If it is like mine. You can pull back on the wire leading to the plug and then the cap will come off. It is spring loaded on some of them.
TedMo 05-04-2010 09:22 PM
That's probably the type you have as Goirish states
DarZeelon 05-07-2010 10:22 PM
With a hammer and a chisel, maybe?
:D:D
NM2K 05-07-2010 10:42 PM
"Have a engine that has a Ace remote glow and I need to take off the engine but can't get the stupid connectors off the glow plugs, I'm stupid, how do they come off?"
Read more: http://www.rcuniverse.com/forum/m_97...#ixzz0nJ1lpeHf
A .357 Magnum. Works every time.
Ed Cregger
DarZeelon 05-08-2010 12:05 AM
ORIGINAL: NM2K
''Have a engine that has a Ace remote glow and I need to take off the engine but can't get the stupid connectors off the glow plugs, I'm stupid, how do they come off?''
Ed Cregger
Ed,
I was never aware Magnum (Sanye, ASP, SC) is offering an engine of this 'displacement'...:eek:
Does HobbyKing also offer them?
Hmmm...
:):D:eek:
jay1st 05-08-2010 06:30 AM
If it's the one in the picture, just pull on the wire and lift the cap.
It's spring loaded, have the same on a SAITO.
[img] http://www.heliproz.com/images/RVO1015.JPG [/img]
EDIT , why is it not showing up ? anyway click on the link to see it !
