RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   unknown engine (https://www.rcuniverse.com/forum/glow-engines-114/9736204-unknown-engine.html)
Scratch One 05-15-2010 08:22 PM
unknown engine
Hi Gents,
I need your assistance. I have an unknown 2 stroke engine. The only marks on the engine are: one one side of the case is the letter M with a line above it, on the other side there is a number 12, on the bottom side of one mounting lug there is a letter S, on the other lug there is the number 70. Other than a grey/black cylinder head, those are the only identifying marks. It looks to be larger than a 60 size and perhaps about the size of a 90. Any ideas?
Regards ,
Scratch One
The Ghost 05-15-2010 08:29 PM
RE: unknown engine
Photos may help.
Cheers
Hobbsy 05-15-2010 08:36 PM
RE: unknown engine
1 Attachment(s)
Need pitchers bad. Does the construction resemble either of these. One is a MOKI .61 LS and the other a MOKI .51 RC. The .51 has an M and a 5 on it.
Scratch One 05-15-2010 08:56 PM
RE: unknown engine
Regarding the "unknown engine, I will try to get some pictures for the next post. It does not look like the engines in the photos. In the meantime, the engine is a one piece case and the exterior is not smooth like most engines. It has a "sandpaper finish." In addition, the needle valve has a built in flexible spring. It is not an air bleed carburetor. Now you have exhausted my knowledge of the engine.
Thanks for your replies.
Scratch One
Hobbsy 05-15-2010 09:26 PM
RE: unknown engine
1 Attachment(s)
That finish almost sounds MVVS like, this is an MVVS .91 that has the finish you describe. Sorry to be wearin ya out.;)
