RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   easy sport 40 engine (https://www.rcuniverse.com/forum/glow-engines-114/975633-easy-sport-40-engine.html)
harleymon2002 07-20-2003 07:45 PM
has anyone had luck putting an os fp60 on a great planes easy sport 40 ??? i have an fp60 and plane is on its way. let me know
thanks!
rik1024 07-20-2003 09:29 PM
Hi a freind that i fly with has a 91 os on a easy sport 40 this thing screams i have never seen one do the things this one dose . iI think a 60 should be ok they made a easy sport 60 at one time it was a little bigger than the 40 but not very much. it bulds the same in the kit form. :cool:
w8ye 07-21-2003 12:12 AM
The Easy Sport needs a little more power than a lot of other 40 size planes. They need at least a strong running 46.
There was one at the field at one time that had a ST75 on it. It honked along pretty good.
He eventually destroyed it showing off.
Some fuel for thought...
Easy sport 40 has a 58 X 10.75 wing with a 1.75" thickness
Big Stick 60 has a 58 X 10.75 wing with a 2" thickness
They both have 623 sq in area.
So therefore the Easy Sport 40 should easily hande a 60 size engine.
However, a Falcon 56, though it has lines very much like a Easy sport 40, is a much smaller plane with the 30 - 40 size engine in mind. They only have a 56 X 8.75 wing that is only 1.25 " thick. It only has 490 sq in wing area.
Enjoy,
Jim
RaceCity 07-21-2003 12:55 AM
Not to pee on anyone's cornflakes here but...
The Easy Sport is essentially GPs version of the CG Falcon 56. A intermediate trainer. It's not a 3D machine...nor a pylon racer nor even impressive for that matter. It IS however a fine flying model when powered with the engine the manufacturer recommends...that being a .40-.462C.
When you start piling in all sorts of metal to the nose...you open up a can of worms.
Good Luck!
'Race
