RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   fa 80 (older) (https://www.rcuniverse.com/forum/glow-engines-114/9871590-fa-80-older.html)
ctufte 07-17-2010 11:16 PM
fa 80 (older)
I am having trouble getting decent power out of it. will only turn a 13x6 at 8800-9000... is it cooked? How do you adjust valves? I just feel like it should have more power. At least as much as a friends OS 70 surpass, and I do not feel like it does? Suggestions please...
rambler53 07-17-2010 11:52 PM
RE: fa 80 (older)
http://www.rcmplans.com/issues/reque...-011987-1.html
w8ye 07-18-2010 01:59 AM
RE: fa 80 (older)
The cam timing may be advanced one tooth?
Valve clearance is .002" - .004"
http://saito-engines.info/
rcdude7 07-18-2010 02:05 AM
RE: fa 80 (older)
A healthy saito .65 will turn a apc 13X6 @10K rpm. Does your engine have strong compression? There are many things that could cause a lack of power.
ctufte 07-18-2010 02:57 PM
RE: fa 80 (older)
The compression is good. How would one check the cam timing? I am not sure how to even check and/or adjust the vaves? What am I looking for? The instruction manual is not very helpful in this regard.
w8ye 07-18-2010 06:50 PM
RE: fa 80 (older)
To check cam timing on an assembled engine
Remove the valve covers
Find top dead center on the compression stroke
Rotate the prop 360 degrees and both valves should be partially open - one closing and one opening. You can look across the tops of the rocker arms and they should be parallel with each other
