Thred size on a glow plug?
Hi guys. I need to know the thred size of a glow plug so I can buy a tap and die. Thank's Jack.
Jack,
glow plugs have 1/4-32 threads . Can be a bit hard to find. Ken |
Ken thank you very much. Jack
try mcmaster carr www.mcmaster.com, or microfasteners for this tap
I tried the Mcmaster link with no luck. I think Harry Higley sells the tap and die,
Jimmy If you remove the "." at the end of the link it will work. FYI |
I must ask. Why do you need the die if you are going to tap the hole?
Ed S |
No he doen't want the die. When he gets the PRICE of the tap it will KILL him.
.............................. "buy a tap and die" get it ? Then they can play TAPS for him . In that case it's DIE and TAPS ! |
All this wierd humour.
It just Taps me right out! Ed S |
Hey! I thought it was funny.
It's good to have a die to correct poor threads on the glowplugs before you screw 'em into your engines. Most stripped glow plug holes are caused by poor threads on the glow plug. |
| All times are GMT -8. The time now is 10:22 PM. |
