Ryan STA/STM Brotherhood
#301
It was a Fine and Pleasant Misery
So yesterday I actually got some time to work on the Ryan and to quote the title of one of outdoor writer Pat McManus "It was a Fine and Pleasant Misery"! Let's see, I discovered F-13 former was missing the slots for the building crutch so I cut those. Next since it was going to be difficult to do so after gluing it in I decided to build the tail wheel assembly. First I couldn't find any 4-40 machine screw the correct length, nextI discoverd I didn't have any 4-40 blind nuts or self locking nuts, just standard nuts. The I blew an hour finding the correct control arm that would allow me to cut it down and still drill a hole for the clevis. Then I discovered I had no 5/32" piano wire so that shot down making that assembly. Next I decided to go ahead in glue a few fuselage formers only to discover F-12 had a crutch slot on one side that was only 1/2 the proper length. Next I broke 3 balsa formers in half trying to get them installed. I finally determined I needed to add a piece of balsa the same dimensions of the crutch material to one side of each former between the building crutch slots. I got about 4 of them glued up and the formers reassembled before it was time to clean up for the night. I shot down a whole afternoon and got about of 45 minutes of worthwhile building time in. Like I said "It was a Fine and Pleasant Misery"! (Sigh) Some days are just not worth chewing your way thru the straps!
#302
My Feedback: (9)
#304
I continue to work on the Ryan SC here is the fuselage in progress. Once all the formers are in place I can start the planking job to form the fuselage skin. First I have decided to drill the firewall and station 2 so the firewall is held by 6-32 screws and blindnuts at 6 points rather than glue it in place. This will allow better access to the compartments for the tank and battery. The tail wheel assembly was made in advance because once glued in place it cannot be accessed. The planking will need to be paused at some point to install the vertical stabilizer and concealed flexible pushrod for the elevator. The horizontal stabilizer mounts inside/thru the vertical fin and the pushrod must pass thru the vertical stab to reach the elevator. Just one of the joys of scale building!
#306
SO ..
I picked up an STA-ARF used, Tower Hobbies 70" version. This plane was used, in great shape and had been flown... Some rash, but clean and happily purchased from a very nice gentlemen in central Florida. I flew it once and so it sits in the hanger. Shes a bit of an evil bird, not badly mannorred full of fuel, but 2/3's empty and she's and evil ^^*(%#^%@ at landing.... a tail happy nasty thing. I could have brought her in a bit faster... (did on the second flight) but once down she tried(s) to nose over.. a little up and she launched right back in the air... at stall speed. Almost tumbled the girl. SO!
I'm going to move the tank over the CG and servos up front to try and keep it light. Any suggestions from the Fan base before surgery!! Thanks in advance for your thoughts and expertise.
#307
OH
ok guys have a 92" Ryan sta can't find the kit builder it has a one piece wing and the tail wheel is per say connected to the rudder internally its a white black an red and it used to have a super tiger glow 3000 in it just trying to find the builder brand its about 15-20 years old and the pants and cowl have the green gel fiberglass in it if that helps yes please help
#308
Byron Originals used polyester resin from United States Steel Corporation. They add a green dye to the resin as their personal touch, or trademark. I don't remember all of the Byron's kits, but I think they had an STA in their lineup?
