Go Back  RCU Forums > RC Airplanes > Golden Age, Vintage & Antique RC
Reload this Page >
Digipace II Will Not Discharge 5 Cell Packs
Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Old 07-04-2016, 04:02 PM
All Day Dan
All Day Dan's Avatar
Default Digipace II Will Not Discharge 5 Cell Packs
I have two new Ace Digipace IIs that will not discharge 5 cell battery packs. When I activate the discharge switch the units switch to charge immediately. The packs are fully charged and maintain their voltage under a .5 amp load. The Digipaces work well with a four cell pack. Any ideas? Thanks, Dan
Old 07-05-2016, 10:10 AM
jaymen
jaymen's Avatar
Switch S4 could have a bad contact.
Old 07-05-2016, 02:43 PM
All Day Dan
Thanks Jay. I'll give it a good cleaning with some contact cleaning solvent. I would hate to have to try to replace it. Dan.
Old 07-06-2016, 05:06 PM
All Day Dan
Jay, according to the schematic and position on the board the cell selection switch is S3. I cleaned the contacts as much as I could and operated the switch more than a dozen times but no luck. There may be more to this than just the switch. The two units are brand new. Dan.
Old 07-13-2016, 02:26 PM
EloyM
My Feedback: (194)
Send them to Jay and let him worry about it!
Even if they are new, they are still old (90s or so) and it may be that age has caused some component drifting and the cut-off voltage has changed. I have information on how to recalibrate it - the cut-off voltage. It states that "it is necessary to t have an accurate digital voltmeter". Bear in mind that a Horrible Freight freebie voltmeter does not qualify as "accurate".
if you want a copy of the info, send me you postal address & I'll send one off. Eloy (Santa Ana)
Old 07-14-2016, 02:39 PM
jaymen
jaymen's Avatar
R24 controls the cutoff voltage in the 5,6,and 7 cell position. It should be 1.58K for five cells, 1.87K for six cells. Maybe someone set it up for 6 cells instead of 5 cells.
Old 07-18-2016, 02:14 PM
All Day Dan
Thanks Eloy, I just received the information. I appreciate the inputs but I'm ready to switch and go modern. I ordered a two cell 2500mah LiFe pack from NOBS Batteries. I'll get my 90 minutes of flying out of them with a more than two to one margin. After some bench testing I'll put it in one of my planes.Dan
