Any Scientific Miss America 80" build logs out there?
I have a friend who purchased these plans from AMA (Scientific Miss America 80") and is having trouble visualizing putting together the wing center section. We have searched Google for any build logs and have only come across articles and pictures about the plane, but not the actual process building it. Hopefully, someone documented their build or maybe can communicate with him the process. We are in San Antonio, Texas.
Thanks in Advance,
Bryan and Toby
Thanks in Advance,
Bryan and Toby
From the plan on Outerzone it's clear that the center section is built flat using a dihedral brace that is flat in the center. Center gets sheeted over, which is good for holding up to rubber bands (use lots of them!). Looks like pretty typical model construction. If unclear, improvise! Main thing is strength across the flat section extending into the wings. The dihedral brace should do that. It's just a model airplane designed by a guy who was a probably a teenager at the time. Make it up...and do a build thread. Good luck to you guys.
https://outerzone.co.uk/plan_details.asp?ID=5645
Jim
Jim
Hi. I've just started building a laser cut kit version of Scientific Miss America, started this blog which I'll add to: http://www.rcuniverse.com/forum/gold...ca-1936-a.html
Wayne
Wayne
That's useful - the plans gave me some ideas on how to tackle the steerable tail wheel dilemma - given that the rudder is above the horizontal stabiliser and blocked from below by it.
