Miss Martha Plans Needed
My Feedback: (14)
Hi All,
I'm need a copy of the original Miss Martha plan. I need to build a new fuse. If any of you have the original plan, could I you please make me a copy (I will pay you for the copy if needed). Actually, if I could get the dimensions of the firewall, the two bulkheads, the distance/measurement of the third bulkhead location from the front of the firewall, and the same for the ply wing bolt plate. I should be able to wing it with the above as I made a balsa fuse templet when I built the first Miss Martha. I have the plan but can't located it and the set on Outerzone are not the same as the original. If anyone can help me out would be greatly appreciated.
Ron
Ron
deleted - I didn't see you had already found no satisfaction with OuterZone.
How about this one?
https://aviationshoppe.com/airplane_....php?file=1126
How about this one?
