Engine and Old Radio Hep
Folks
I got back into RC after many year abscence. I'm helping a widow clear out an estate and she has several engines, older than I can
identify( pre 70's) > She also has two transmitters. Both by Orbit. One single stick and one dual stick. Any way to find the value of the engines or the radio. Also looking to sell. Would prefer to make a single transaction. Not looking for a lot of money. Just something fair from someone who would value them personally
hey when the planes you started on are now aniques, so are you
RE: Engine and Old Radio Hep
Need to get the engines identified first. Pictures are best (don't ask me how to post them here) but a description of each engine might get something going.
Jim
Jim
LA
I recommend that you use a digital camera to make a .jpg file then upload.
For the pre - 90 radio's I assume they are AM and not narrow band. Therefore the value would be low unless someone wanted to spend the $$ to convert them. You didn't mention if you had any receivers,, servos etc. Take a pic and then use the Click here to upload at the bottom of the text entry block.
You can also scan the items and convert the scanned pic to a .jpg and upload the same way. Good Luck. Jim
ORIGINAL: jimcork1
Big Max, You got all that right! It is a Fox 07 with a McCoy needle. I couldn't find a Fox 07 needle so I tapped the spraybar 2-56 for the McCoy needle and it worked OK. It has found a new home in Australia. It was one of two little junkers off ebay. Fixed them both up to run, made a couple of buyers happy, and cleared a couple of bucks.
Jim
Jim
