Full Size Dallaire ... C/G?
ON, CANADA
Hi Guys
I have a full size Dallaire and I'm not quite sure of the c/g point. How far back from the leading edge is it? I'm guessing about 33%. Any help appreciated before I maiden it. Thanks!
Frank
Frank
My Feedback: (7)
RE: Full Size Dallaire ... C/G?
25% to 33% is a good rule of thumb as to mean chord. However, it's one thing to speculate on balance moments for model planes, quite another for one you are going to climb into. Surely, there are better sources for the specific info you need than RCU? Best of luck with your Dallaire.
My Feedback: (113)
IL
On my plans from Campbell's Custom kits Dallaire Sportster (108 in span) the C.G. is located 5.25 inches from the leading edge. Good luck with the maiden flight. Ray
ON, CANADA
Thanks for the info Ray, appreciated. According to my calculations at 30% I am a bit nose heavy. I'll have to play with the balance to get it right. I am flying this in Texaco at our Canadian Nats.
Jim, full size Dallaire is 108". I don't know a lot about old timer planes, but I have only heard the 108" Dallaire referred to as full size, there also is a 1/2A size too. The Dallaire was made by Frank Dallaire of Dallaire Models in the early 40's. I'm sorry if I scared you, thinking I was going to climb in and fly it.
Frank
Frank
Frank, old timers have large enough stabilizers and long enough tails that they can easily get away with much further back CG's than is "normal". So don't be afraid of 35 or even 40% back.
Your best performance will come with the CG back just a few % in front of the neutral point. Look up the "dive test" as it relates to RC sailplanes and use the same procedure to sneak back the CG to where you get the best performance without sacrificing stability.
ON, CANADA
I rebalanced my plane at 5.25 behind the leading edge, I had to take out some nose weight (a good thing). The plane flew real nice. Take off was smooth. It climbed out and up to a spec. It got pretty high so I shut the engine off. The glide is nice and slow, and it sinks so slow. My flying field is surrounded by 10 foot corn, so I overshot the field and had a gentle landing in the corn. Good to go again. Thanks for the help guys!
