Fly Baby
AZ
Fly Baby
I have a Fly Baby bipe that I have flown for a couple of years. Its just a pain to assemble at the field.
I am thinking I should convert it to a monoplane. I have it fixed so I can remove the cabane struts. Does anyone have the plans for the monoplane wing that I can purchase? The airplane I have is the Balsa USA kit
RE: Fly Baby
According to Charlie Munneke, who I fly with and who is building the monoplane and has built and cuts out a shortkit for the bipe, the wing assemblies are radically different. For one thing, the monoplane has fold back wings (this is scale).
Woops
Woops
AZ
RE: Fly Baby
The wings are different but they both bolt on the same fuse. Do a search on the Fly Baby You will turn up a site that describes how Pete Bowers could convert from monoplane to biplane in one hour.
I just wonder if they had the same cord. The biplane had swept wings the monoplane did not.
NY
RE: Fly Baby
I also have the Balsa USA bipe. Why not cut the fuse in two behind the cockpit and leave the wings attached to the front fuse section? Then modify the fuse so it can be put together and taken apart with a couple of bolts. The elevator and rudder servos can be repositioned to the rear fuse section and connected up with leads to the receiver at the fuse joint. No need to take the wing cabane struts and "N" struts apart again and again. Should assemble in less than five minutes!
