Spark Ignition makers
I would like to convert a os fs 60 open rocker to spark. Have talked to C.H. ignitions,but he mostly have systems for large gas engines(zenoah, etc) now.
Who else sells a bolt on kit ?
PA
Possible sources are [email protected] and Larry Davidson at [email protected]. These were listed in an extensive article on old timer engines by Jim Alaback in the December, 2001 issue of Flying Models but perhaps they can help you with a more modern engine.
Dave Segal
Dave Segal
FL
I have the same engine. I had al diem of trans sil convert it and it is a beauty. I have run it in a ben bukle flying quaker (silk and dope) and it was and is a great combpo. I run mine on glow fuel with the ignition and it runs perfect. do not try gas as it runs to hot and the needle will have to be worked over
