Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Aamco Minimaster
Old 06-25-2008, 06:30 PM
pd1
Default Aamco Minimaster
Due to the kindness of a member here, I now have some plans of the Minimaster.
I started cutting parts two weeks ago and the plane is ready for a test flight.
I worked at Aamco for a bit in the late 60's and early 70's. I also got to build the pre production one.
I always liked the Minimaster, it had some quirks, but it still could fly well.
When Lou started AAmco, the first planes were the H-Ray and S-Ray. These two shared a lot of common parts.
When the Mini was drawn up, it had a buddy.
The next plane was to use the wing and stab from the Mini and it's own fuselage.
Lou built the first proof of concept Mini. It had a non sheeted wing with egg crate construction for the spar and ribs.
The leading edge was to be a heavy shaped leading edge, similar to Sterling and Goldberg kits.
The first pre production wings almost fell together, a lot like his Box-Lok fuselages did.
When production started, all was not well. The heavy material for the wings relieved themselves once cut.
The parts were unusable.
Lou redesigned the wing, a new sheeted wing took it's place.
This took quite a while because there was a six to eight week wait for new balsa to arrive.
The plans had to be redrawn too, also time consuming.
The first and only run of Mini's started in the new facilities, another hassle.
The run was 3, 300+ kits. I don't remember the exact overage.
I got to build the plane for the photo aid sheets and to double check the parts fit.
Basically it was the first one from production parts.
The plane didn't sell well.
A few people had problems with snap rolls on takeoff.
The plane was in a transition period. A lot of people had proportional radios, but a lot that bought the Mini still ran reeds.
Reeds and heavy servos made the plane overweight, and the current philosophy was for takeoff hold up elevator till it broke ground.
This often resulted a snap roll.
Enough history here's my latest plane ,2 pounds 12 ounces ready to fly.
Oh, and electric powered.
Paul
ID:	978494   Click image for larger version
ID:	978495   Click image for larger version
ID:	978496   Click image for larger version
ID:	978497   Click image for larger version
ID:	978498   Click image for larger version
ID:	978499   Click image for larger version
ID:	978500   Click image for larger version
Old 06-25-2008, 08:21 PM
maxpower1954
Default RE: Aamco Minimaster
Nice job - Another airplane I always wanted as a kid!
Brushless motors, li-pos and tiny radios allow these older designs to reach their potential. Russ Farris
Old 06-25-2008, 10:49 PM
MrMulligan
My Feedback: (314)
I remember the one I had. I had powered it with a new OS Max .25. This was before the FSR's came out. It flew great but you had to be careful landing it. In the air, it was a "rocker", rocking side to side. I cured it with reflexing the ailerons up about 3 or 4 turns. That cured that. I finally lost it when it snapped on landing and little was left. That .25 was a good engine and I was often asked if there was a larger engine in it.
Old 06-26-2008, 03:34 AM
gene6029
gene6029's Avatar
Really nice models, i especially like the covering scheme on the Trainermaster.....Gene
Old 06-26-2008, 04:24 AM
pd1
Thank you.
Paul
ID:	978742   Click image for larger version
ID:	978743   Click image for larger version
Old 08-28-2008, 08:23 PM
Jairman
Paul,
Excellent building and covering job! Say is that a Mini-Taruas?
Old 08-29-2008, 06:52 AM
pd1
Yes, it is.
http://www.wattflyer.com/forums/showthread.php?t=19864
Build thread.
Old 03-12-2009, 12:34 PM
bigbird3
pd1, you are right about the snapping! i lost mine in 90 or so when a friend kept snapping it trying to recover from a dive.
i finally found a kit and copied he plans and blew them up to 74"!!!! what a nice plane! i covered it in dark red and platnum with a
phoenix 6 checker pattern. always liked that scheme. i put a 65 LA in it and it was a bullet! only problem was that the fuse at the tail was too narrow and the tail feathers blew off on the third flight! man what a heart breaker! it was a beauty! first time in over 40 years of modeling to have tail feathers blow off!
my good friend Dan Hines in N.C. now has the kit.
bird.
ID:	1156196   Click image for larger version
ID:	1156197   Click image for larger version
ID:	1156198   Click image for larger version
ID:	1156199   Click image for larger version
ID:	1156200   Click image for larger version
ID:	1156201   Click image for larger version
Old 03-12-2009, 02:19 PM
WORNBOOTS
My Feedback: (33)
WORNBOOTS's Avatar
That's an excellent job on the MiniM as well as the the other two in your pics.
I soloed on the TrainerM back in 78 when I lived in Taft Ca. it was a good flying plane for me with little skill back then.
Trying to collect most of Lou's designs over the last few years has been fun and costly, I wonder if he ever thought the the H-ray or Trainermaster would pull the prices they ere now.
Thanks for the bit of history as well........... Dan
