Breezy Jr. By Babcock (Low wing Version)
ON, CANADA
1 Post
I have an old Breezy Jr. plan of this fine shoulder wing design. I believe the Breezy L which is the low wing version had a simple addendum to the plan that would allow it to be built as a low wing plane.
Would any one be able to copy the low wing version for me?
Bob G
Bob G
Hi Bob;
Greetings to you up in Peterborough, Ontario, from the 'Oven'.
[spent the first 36 yrs of my life in Ontario, down along the N shore of Lake Erie; tobacco farm country, so our paths may have Xed somewhere up there.
I rec'd your private message re the Low Wing Mods to the Breezy Jr. My plans, like yours show only the mid wing version. I have an original kit box, + a pretty beat up airframe...extremely lite...I have never heard of a low wing mod, but why not do one yourself; like refer to RCM plan for the Miss Bikini, Plan # 407 in the 10/69 issue, quite similar in size, but the Miss B has a fully semetrical airfoil. I also have a complete mint Breezy Sr. kit, and it too is a mid-wing, and I do not see mods for alow wing on it either. I will do some more research, and see if I can locate any other small 1/2A type low wing designs with a flat bottom airfoil, hmm, wasn't the Tidewater PLAYMATE a low wing with a flat foil..?
I'll get back to you later, I tried to answer you back privately, but fumbled, so am herein, best of luck on your quest, and best regards from sunny and real hot Phoenix,
Joe Nagy.
Joe Nagy.
