Name the plane-with clues!-repost
TN
Reposted from another thread........
Here's another one...x'cept it's gonna really stump ya (it's in disguise)
I will give you a "clue" as I really don't know what the model is....I just had some "fun" with redesigning it and cut maybe a pound or pound and a half of plywood out of it. It's now 3# 5 OZ no fuel but all up. and I have an OS 25 FP on it. The original motor was an HB 25 and I have made a muffler for it. The HP runs circles around the OS (even though OS is nearly new), but I'm going to maiden with the OS.
Don't get confused with the trim scheme....thats another discussion.
The "clue" is it had "Pilot" stamped on the ribs...so its a pilot kit. I never owned a Pilot kit , but the owner of the plane gave it to me and it was a real mess. Much repairing and strengthening and lightening later...we have this. Canopy was destoyed
I thought the wind would hit 5MPH today..to maiden...but its still running about 9-10 here in East Tenn.
TN
RE: Name the plane-with clues!-repost
ORIGINAL: WEDJ
Very similar to an r/c Top Flight Flite Streak, which was a c/l plane. But the fuselaga top reminds me of the TF Contender, too.
The plane is a Pilot kit though...
BTW...I am thoroughly enjoying the .020 Skylark thread you posted...you have that silk looking fabulous!..and a "how-to" on thread hinges...great!.. I will be doing some thread hinges (will use matching color thread)on at least 2-3 planes (Skampy, Allstar, Chief) as they are finished soon. Was starting to finish and got side-tracked with the old RCM trainer 3 ch I had (circa early 70's) and I've been degreasing...yep, the old talcum powder and sanding way.!
Possibly a Pilot QB 20L. Trike u/c with Quick Build construction. Haven't seen one for a long time so I am probably wrong!!
Chris...U.K.
Chris...U.K.
TN
ORIGINAL: flying pastor
Chris...U.K.
Chris...U.K.
That sounds like a probable prospect... The plane is a bit large (and a was a bit heavy-lots of plywood to last through beginner pilots) for the .20...but would have allowed anything to and including a .35...maybe even a .40
I will try to google that model, perhaps someone has a few pics of theirs..
TN
Chris...U.K.
Chris...U.K.
I think your 100% right
Here is a pic off the web (there was only 1 I could google) so its gotta be a bit rare and somewhat older plane.
I do remember a piece of balsa stamped QB or quik bilt. The box shown is the evidently a version II . I would think I have version I. Straining my memory (of all the old mag rags I had read), the difference might have been lower weight and a symetrical airfoil(I would think). The airfoil I have is a semi-symetrical.
The carb that was on the HB 25 was a Weber carb and I have not found one to replace it. The fuel feed nipple was pulled out so I had to "manufacture" one with brass tube and JB weld ......looks odd, but works. If I had wanted to restore this as a rare bird, I would have first located all engine parts and a muffler (I found a new muffler from MECOA)and proceeded to finish it original. Since it was not a popular OT type plane, I just decided to have some fun in the redesign...and now it kinda passes for the Top Flight Flight Streak , which no one that I know has ever tried to make R/C. This plane is NOT the Flight Streak...but I think it would make an interesting conversion. No, the Flight Streak wouldn't be a 3D plane...nor even a good sport flyer , but would make one heck of a combat wing and look like a million dollars. The paint scheme was a challenge as originally it was easy to do with silkspan and dope , but when you start laying two layers of film over ribs, things go south real fast. ...so I had to actually cut the color gores out and piece them together(1/4" overlap") (and iron the edges) while off the wing frame...then lay and postioin the whole thing on the wings and then tack it down (much easier said than done)
It was a fun rebuild and it looks like it will fly well...I hope I get to maiden it in a few days as we are finally getting what I call flying weather hee in E Tenn.
TN
Maiden flight was Great!.....except
I had to use all my up elevator trim... You may be able to see the down trimmed elevator (pic was taken at zero trims)
4 OZ tank...and on about second fly-by I made a low speed pass (getting used to approach) and powering back up noticed engine leaned so went to 1/2 throttle.
about 100' up and downwind leg, engine quit...so next manuever was landing...and was uneventful. The plane had fabulous low speed control and no tip stall tendecies .(even though I kept speed a bit higher due to maiden flight). Overall was very smooth and predictable.....something and OT like me needed after years of not flying often.
Still not found why motor quit...but will. Tank still had 4/5 fuel left in it and clunk was free.
