SWIZZLE STIK
Hi Anyone know were i can find a set of SWIZZLE STIK plans?
Thanks |
RE: SWIZZLE STIK
Call Balsa USA they have all the plans in stock and I think they still make the kit
RE: SWIZZLE STIK
As you look around, your gonna find that the Swizzle Stick was discontinued 30 years ago....But a few are still out there, and plans will be fairly easy to find....
RE: SWIZZLE STIK
ORIGINAL: SoonerAce As you look around, your gonna find that the Swizzle Stick was discontinued 30 years ago....But a few are still out there, and plans will be fairly easy to find.... -------------- While the 3-channel Swizzle Stik may be extinct, there are, or were, four channel versions available from Balsa USA for quite a while. The Lite Stik is basically a Swizzle Stik with ailerons. |
RE: SWIZZLE STIK
Balsa USA sells modern versions of the Swizzle Stick called "Stick 40 (3 ch.) and Stick 40 Plus (4 ch.). Their website address is: www.balsausa.com. They also sell a wing kit for the Stick 40 Plus. I built the Swizzle Stick about 30 years ago and the Stick 40 Plus recently. They are very similar.
nanavion46 |
RE: SWIZZLE STIK
1 Attachment(s)
Here's a photo of the Stick 40 Plus:
RE: SWIZZLE STIK
Those plans originally appeared in RCM magazine and should be available from their plans service if it's still operating. I think they had three different sizes. They were called the Quik Stik.
RE: SWIZZLE STIK
Just now building a Stick 60 from old balsa usa blueprints that an mr M.F. Schwarz JR in Tennesee so kindly copied and mailed me. Wing span 2,0 meters and an SC 60 up front. That was a year ago, if anyone knows of mr Schwarz new email adress, pls let me know. Johan A, Sweden
